Old 11-28-2020, 03:32 PM   #1
charlesea
charlesea's Avatar
Default F-100 steering box conversion
Looking for an F-100 steering box conversion for a 28/29 sedan.
I know there was fellow in Calif. that was selling those but not sure whether he is still doing that.
Thanks for any help.
Charles
charlesea is offline   Reply With Quote
Old 11-28-2020, 03:46 PM   #2
wmarcy528
Default Re: F-100 steering box conversion
https://www.fordbarn.com/forum/showthread.php?t=273518
wmarcy528 is offline   Reply With Quote
Old 11-28-2020, 10:08 PM   #3
Herb Concord Ca
Yes he is. His name is Randy Gross you will find him in the Swap meet section, he lists brake drums and shoes and also F-100 steering. A good guy to work with.
Herb Concord Ca is offline   Reply With Quote
Old 11-29-2020, 12:30 AM   #4
Chris Haynes
Chris Haynes's Avatar
Randy
714 292 8660
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-29-2020, 12:35 AM   #5
McMimmcs
McMimmcs's Avatar
Randy Gross is a true professional and guarantees satisfaction. Very experienced and helpful.
Old 11-30-2020, 08:18 AM   #6
old31
I agree, Randy is a professional.
old31 is offline   Reply With Quote
Old 11-30-2020, 04:46 PM   #7
bosticjb
I put Randy's brakes ND STEERING ON MY 28 GOOD GUY TO WORK WITH
bosticjb is offline   Reply With Quote
Old 12-13-2020, 05:22 PM   #8
charlesea
charlesea's Avatar
Thanks for the get back on Randy Gross.
Sorry so long in getting back. Been out of town out of town .
Old 12-13-2020, 07:17 PM   #9
DBrer
I had Randy do my brakes and he was great to deal with. he took the time to explain what needed to done and my brakes work flawlessly. I would definitely use him for a steering upgrade.
DBrer is offline   Reply With Quote
Old 12-14-2020, 05:45 PM   #10
john in illinois
john in illinois's Avatar
I tried one and did not like it. I rebuilt my original and used a shortened pitman arm.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 12-15-2020, 08:17 AM   #11
Bob-A
Bob-A's Avatar
Smile Re: F-100 steering box conversion
I'm not knocking Randy Gross and I'm sure the up dated steering gear he builds is first rate. However, if you rebuild your original (2-tooth or 7-tooth)
steering gear correctly. It will be just fine, maybe not as smooth & easy as your new auto. But, heck it is a 90 year old car! I'm the first person to admit
that I am no mechanic. Yet, I have rebuilt one 7-tooth and two 2-tooth "A" steering gears and they all turned out good. Take your time and always use new bearings ,bushings, sector shafts and worm gears. I also use the shortened pit-man arms. Good luck.
Bob-A
PS: Never try and turn your steering wheel without the car moving or the front end jacked up. It is very hard on your steering gear.
Bob-A is offline   Reply With Quote
Old 12-15-2020, 08:58 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
The more senior of us find the Model A's steering to be hard on our arms and shoulders. So there is a need to make the steering easier.
Bob Bidonde
Old 12-15-2020, 11:35 AM   #13
duke36
The F100 boxes use the roller sector shaft like mid 30's -on vehicles. Easier to steer but sometimes difficult to adjust out the free play. Btw, a shortened pitman arm on a stock gear most often needs an adjustable drag link (see other threads) to adjust for zero freeplay at the gear centered and wheels straight ahead.
Old 12-15-2020, 01:12 PM   #14
McMimmcs
McMimmcs's Avatar
John
I am very surprised , Why did you not like it ? You’re the first person I’ve heard say that !
Old 12-15-2020, 03:36 PM   #15
Bob C
John
Did you use one from Randy or someone else?
Old 12-15-2020, 04:02 PM   #16
Mel Gross
FYI
I sent a PM to John in Illinois and offered to refund his money upon the return of the box if he bought it from us. We strive on making sure all who buy from us are satisfied.
Randy Gross
714-292-8660
[email protected]
Mel Gross is offline   Reply With Quote
Old 12-15-2020, 05:09 PM   #17
Joop
Joop's Avatar
Super Service Randy.
I have 2 and love them.
Joop is offline   Reply With Quote
Old 12-15-2020, 05:19 PM   #18
john in illinois
I did not get it from Randy. I know he does good work. I simply did not like it as well as the original box.
Welcome each day
Old 12-15-2020, 10:12 PM   #19
Bob C
Wasn't one of the EZ Steer by john kovar was it.
Old 12-15-2020, 10:23 PM   #20
GRutter
GRutter's Avatar
Hats off to Randy. A true example of a great vendor.
He didn't even question how long he had it.
I purchased brake drums, shoes, a hub, bearings etc from Randy. Everything was fine.
GRutter is offline   Reply With Quote
