Old 09-29-2020, 02:02 PM   #1
ModelAAfreddie
Default Toe in procedure.
Hello! Long time listener, first time caller.......
Can someone explain toe in, and what should be done to the model a, and how, to be appropriate?
Thank you in advance! Gene
ModelAAfreddie is offline   Reply With Quote
Old 09-29-2020, 02:21 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Toe in procedure.
Welcome to the club.
Here is a short, short version. Toe-in is where the front wheels 'fight each other' as they are just slightly angled in towards the center of the car.
That being said, what needs to be done to your car? A great resource is Les Andrews first book-red I think. It will give you a step by step breakdown.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-29-2020, 03:06 PM   #3
J Franklin
J Franklin's Avatar
Your local tire/alignment shop can do the job if the front end parts are in good condition.
Old 09-29-2020, 03:53 PM   #4
160B
160B's Avatar
here is a online video
I believe that the correct toe in is 1/16" plus or minus 1/32"
https://www.bing.com/videos/search?q...tail&FORM=VIRE
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
Last edited by 160B; 09-29-2020 at 04:07 PM. Reason: correct toe in to 1/16 plus or minus 1/32
160B is offline   Reply With Quote
Old 10-01-2020, 06:30 PM   #5
keyswitch1
Does any body no where to buy a toe in gauge ??
keyswitch1 is offline   Reply With Quote
Old 10-01-2020, 06:56 PM   #6
160B
160B's Avatar
They are available on Amazon
https://www.amazon.com/s?k=Duby+Wheel+Aligning
Old 10-02-2020, 05:10 AM   #7
shew01
shew01's Avatar
Brent Terry posted about toe plates a while back. I think he uses something like this.
https://www.jegs.com/i/JEGS/555/8168...iABEgKgxvD_BwE
Old 10-02-2020, 09:46 AM   #8
Purdy Swoft
Purdy Swoft's Avatar
A weak or sagging front spring will cause front end shimmy . If the back tires are under inflated , it will also cause front end shimmy . I run my tires at 35 pounds pressure .
Old 10-02-2020, 09:49 AM   #9
jwilliams81
jwilliams81's Avatar
I have and use both of these:
https://www.summitracing.com/parts/lng-79620
https://www.summitracing.com/parts/sps-99361
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
