Old 09-24-2020, 12:40 PM   #1
Marmon4x4
Marmon4x4's Avatar
Default Winfield su1a
Just pulled out an old Winfield SU1A thatÂ’s been on the shelf for the last 45 years and though It might be worth putting in a 276 IÂ’m getting ready to build for my 38 sedan. Sent it to Isky to get profiled. Came back with a card with info. Want to know what to expect if I use it. Will be running 59AB heads, stock intake and carb, Harmon and Collins dist, Fenton headers, mild porting and port matching. Duration @ .020 270 intake. 258 exhaust
Cam lift .370 intake. .350 exhaust
Duration @ .050. 240 intake. 230 exhaust Valve lash. .016/.018 Will idle be excessively lumpy? How about low and mid speed drivability? Any help will be much appreciated
Marmon4x4 is offline   Reply With Quote
Old 09-24-2020, 01:23 PM   #2
Pete
Default Re: Winfield su1a
It will have a slightly lopey idle. Fair off idle power, so so mid range.
Old 09-24-2020, 01:30 PM   #3
frnkeore
frnkeore's Avatar
It will be lumpy, for sure, as it has a lot of overlap. I think it will want at least another carburetor, to get the best of it and better valve springs, of course.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 09-24-2020, 02:05 PM   #4
frnkeore
frnkeore's Avatar
This might help and it lists another Isky carded SU1A but, the timing for the lobes is reversed on it.
It will give you a idea of where the cam lays, compared to other race cams.
Frank
'35 Ford Model 51
'48 Ford F3
Old 09-24-2020, 03:36 PM   #5
Ol' Ron
Ol' Ron's Avatar
BY the numbers, it doesn't sound like a very good street cam. Might work at Bville
Old 09-24-2020, 03:40 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
I have a Winfield SU1R cam. Anyone have any specs for it ?
Old 09-24-2020, 03:50 PM   #7
Marmon4x4
Marmon4x4's Avatar
I wasn’t sure if it would work for me. I may end up with 52 mercury grind. Don’t want to have too much cam for the rest of the build. I am going to use Zephyr springs depending on cam choice. I also have a Winfield R1, need to know more about it.
Old 09-24-2020, 06:19 PM   #8
Black Fifty
Black Fifty's Avatar
Frank already posted part of this, but the rest of the discussion is very interesting.
Mike
http://www.tildentechnologies.com/Ca...rformance.html
Black Fifty is offline   Reply With Quote
Old 09-24-2020, 07:21 PM   #9
flatjack9
flatjack9's Avatar
Been running an SU-1A in my 39 with a 276 cu in engine. I like it, still plenty of low end torque. Been running it for close to 25 years now. With OD I get over 20 mpg running a 390 cfm 4 barrel. Sounds great. Very similar to an L-100.
Old 09-24-2020, 08:53 PM   #10
Pete
Winfield cams being among the first ones around are probably the most pirated ones in existence. Over the years I have had at least 15 different cams stamped SU1A come through the shop. Only 3 were genuine Winfield ground by Ed himself.
I ran one of those at Bonneville in 1953 and turned 129. The same engine with a 404A the next year turned 137.
Of all of the pirated ones some were of the same timing and lift and several were totally different. Who knows what they were. One thing all of them including the real ones had in common, they were duds as far as a high performance cam.
Not even a good street cam unless you like a super lumpy idle.
All of the originals I checked were 280 or more duration. Way too much for a NORMAL street engine.
Here are some of the ones I checked over the years.
SU1A (One of the many)
In 28-72
Ex 69-26
In .355 lift
Ex .330 lift
In .012
Ex .014
Velocity .004
Lobe seperation 112
Winfield SU1A (1953) (Another one of many)
360 lift 280 duration on the intake 28-72
360 lift 286 duration on the ex. 74-32
111 degree lobe separation
SU1A (1953) Yet another.
In 28-72
Ex 71-29
Lift .355
Lobe sep. 111
Velocity .005
Old 09-24-2020, 09:52 PM   #11
flatjack9
flatjack9's Avatar
What are the specs on a real Winfield cam?
Old 09-24-2020, 10:29 PM   #12
Pete
The last one listed is the one I have seen 3 of that were actually bought from Winfield in 1953.
Old 09-25-2020, 08:13 AM   #13
flatjack9
flatjack9's Avatar
Thanks.
Old 09-25-2020, 08:28 AM   #14
Marmon4x4
Marmon4x4's Avatar
I just found the cam card on the Winfield R1. @.020, 256/246. @.050, 226/218. Lift .332/.322. Maybe this would be a little more streetable?
Old 09-25-2020, 08:31 AM   #15
JSeery
JSeery's Avatar
That is still a lot of duration.
Old 09-25-2020, 09:08 AM   #16
Ol' Ron
Ol' Ron's Avatar
when looking at the timing of a cam for street use, check the closing of the intake valve. This determines the dynamic compression of the engine,because, compression doesn't start untill mit closes. O the L-100 a cylinder with a static CR of 8:1 will have a dynamic CR of 6:1. This is one reason the L-100 didn't work very well in a stock engine. The loss of compression reduces the amount of torque the engine can produce. I don't have the information handy for calculating this, but I'm sure somebody does.
Gramps
Old 09-25-2020, 09:40 AM   #17
Marmon4x4
Marmon4x4's Avatar
Intake 18/58 @ 020. Ex. 53/13 @ .020. Intake 3/43 @ .050. Ex39/1
Old 09-25-2020, 01:03 PM   #18
frnkeore
frnkeore's Avatar
The Ex numbers @ .050 don't add up I think the 1 should be -1:
18/58 @ .020 = 256* 110 LC
53/13 @ .020 = 246* 110 LC
3/43 @ .050 = 226* 110 LC
39/1 @ .050 = 220* 109 LC
39/-1 @ .050 = 218* 110 LC
276 CI (3.312 x 4) 8/1 Static CR
R1 dynamic CR = 6.72
SU1A dynamic CR = 6.04 (28/72 timing)
Added:
Those numbers are for sea level reduce by .2 per 1000 ft elevation.
Frank
'35 Ford Model 51
'48 Ford F3
Old 09-25-2020, 02:36 PM   #19
Marmon4x4
Marmon4x4's Avatar
You’re right about the -1 on exhaust closing. After was scratched out on the card and before was written in. What’s the drivability for the street look like? Should I be looking for something else?
Old 09-25-2020, 03:39 PM   #20
frnkeore
frnkeore's Avatar
I think the R1 would be more streetable. I would call it more like a 3/4 race cam. Compare it to the Harmon-Collins 3/4 race cam.
Frank
'35 Ford Model 51
'48 Ford F3
