Anyone using NGK plugs in an 8BA? if so any pros or cons?
I'm using NGK's in my blown flathead with excellent results. They were recommended by some well known people here and so far so good. My 2 cents.
Joe |
Me too. B6L in an 8BA style Merc slightly "warmed up". Plugs look just right. Milled 8CM iron heads.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
I have been using them for 15 yrs.
B6L’s working good with my EAB heads.
Al
Thanks Andy 1952 F1 |
Get them for Rock Auto for under $2.00 a piece
Used for the past 15+ years in my 49
Henry Ford designed the flathead without the aid of a computer. |
Lots of positives! Same plug you'd recommend for a stock 221?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Yes
Work fine on my 21 studder...
"Came too close to dying to stop living now!" |
NGK's are one of the only plugs where the electrode is indexed to the threads, if that means anything... I like 'em.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
#13 |
I use the NGK GR4 2635 plugs recommended by Mark Kirby when I bought his heads in 1999.
Work fine. |
#14 |
Thanks guys! I am learning the value of a well tuned ignition system from the slot in the end of the cam to the tip of the spark plugs.
#15 |
The gold color on the threads is something sprayed on to help keep the plugs from sticking to the head so you can never strip the threads when removing the plugs. They break loose easier that way.
I just started using NGK plugs in 1972. I installed NGK plugs in my F1 in 2006 and again in 2016. |
#16 |
#17 |
Yes, B4L (3112) in my roadster.
#18 | |
#19 |
When RONNIE ROADSTER had my 40 this Spring that's what he installed. Runs great.
Paul in CT |
#20 |
