Can a PCV valve have any negative effect on the load o matic distributor on a 8BA. Could the ported vacuum signal to the distribulor be diminished using a PCV connected to the wiper port on the intake? Any thoughts, Thank you.
Ran a PCV for a couple of years while using the loadamatic with no issues.
PCV uses manifold vacuum not venturii vacuum. Does it effect it when you turn your wipers on??
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 07-31-2020 at 12:28 PM. |
