Old 04-11-2011, 07:41 PM   #1
kendall
Default 1949 head light switch removal
is there a trick to taking the head light switch out of the dash on a 1949 F1? after unscrewing the nut that holds the switch in, whats the trick at removing the knob to get it thru the dash hole?......is there a clip or button on the switch to remove the shaft?, or does the knob just pull off the stem to allow the shaft to go thru the dash hole.
kendall is offline   Reply With Quote
Old 04-11-2011, 09:06 PM   #2
TJ
TJ's Avatar
Default Re: 1949 head light switch removal
There's a button on the bottom of the switch. Push it in and pull on the knob. The knob and shaft come out as a unit.
Old 04-11-2011, 10:32 PM   #3
mtflat
mtflat's Avatar
51/52 have a button. 48-50 have a small slot on the bottom side - push a small screw driver into it to release the shaft.
mtflat is offline   Reply With Quote
Old 04-11-2011, 10:52 PM   #4
makemc
makemc's Avatar
if you look up at the bottom of the light switch
you will see a small slot near the front of the switch
put a small screwdriver in the slot and twrist slightly
and turn the knob a little to the leaf and pull, it
should come out of the switch with the shaft attached
makemc is offline   Reply With Quote
Old 04-12-2011, 08:24 AM   #5
Redhorse1947
Redhorse1947's Avatar
Here is a picture of the switch (shown upside down) and the small brass "tab" that must be depressed. Once the "tab" is depressed the knob can be turned about 1/4 turn to the left and released.
Redhorse1947 is offline   Reply With Quote
Old 04-12-2011, 07:26 PM   #6
kendall
thank you everyone, you guys are great. thanks for the picture redhorse.
Old 04-01-2023, 02:29 PM   #7
Seabees
I know this is an old thread, but I wanted to add, after removing the light switch in my '48 F1, that the slot to put a screwdriver in, is on the drivers side of the switch. The tab is pushed to the rear of the switch (towards the firewall), then the shaft can be turned a quarter turn +/-, and pulled out. Then the bezel can be easily unscrewed by hand.
Seabees is offline   Reply With Quote
