Old 07-15-2020, 09:51 AM   #1
Richard Lorenz
Default Neoprene Seal for front of crankshaft
Does anyone have experience with the "new" neoprene seal that goes at the front of the crankshaft. It replaces the rope-type seal.
It is described on page A-131 of Snyder's Catalog.
Richard Lorenz is offline   Reply With Quote
Old 07-15-2020, 11:00 AM   #2
pinball73
Default Re: Neoprene Seal for front of crankshaft
well i put one in when i rebuilt my 29 engine & i am very pleased with it! when i did it i also replied the front pulley, where the seal makes contact, as mine was worn. have not had a problem with it! no leaks, no drips, no runs
pinball73 is offline   Reply With Quote
Old 07-15-2020, 11:26 AM   #3
Smog Tech
Smog Tech's Avatar
They seem to work great I have been putting them on using a front pulley hub (pulley machined off) to hold the seal in alignment while I install the pan and front cover. Saw one that still leaked, think the block was line-bored off-center
Smog Tech is offline   Reply With Quote
Old 07-16-2020, 04:41 PM   #4
john in illinois
john in illinois's Avatar
Mine has always worked well. 12 years,26K miles. Still original from Skokie antique engines.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-16-2020, 05:55 PM   #5
Synchro909
Synchro909's Avatar
40,000 hard miles on mine and no sign of even a weep. I can't see myself ever using a rope seal (never have).
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-16-2020, 11:42 PM   #6
M2M
M2M's Avatar
There seems to be two types:
https://snydersantiqueauto.com/Produ...earchByKeyword
$21.95. A modern neoprene seal that replaces the old 2 piece style rope seal in the front of the motor. The bottom rests in the oil pan, and the top in the timing gear cover. No machining required.
https://www.brattons.com/front-crank...dern-seal.html
$12.50. This is a one piece nitrile (which is better than neoprene) seal, which replaces the two white rope seals (9770). Fits 28-34 and 32 to 53 V-8s.
M2M is offline   Reply With Quote
Old 07-17-2020, 04:25 PM   #7
midgetracer
midgetracer's Avatar
definitely a good upgrade.
midgetracer is offline   Reply With Quote
Old 07-18-2020, 12:10 AM   #8
Ruth
There is a third type seal from Bill Stipe that has an aluminum retainer and press in seal.
Ruth
Old 07-18-2020, 08:36 AM   #9
Patrick L.
Patrick L.'s Avatar
Hmmm, interesting. I've not had an issue with the rope seals.
Old 07-18-2020, 10:25 AM   #10
Russ/40
Russ/40's Avatar
Ditto! I've never had a front leaking rope seal on any V8, or my "A". Consequently, I have never felt the need to change.
Old 07-18-2020, 10:44 AM   #11
katy
katy's Avatar
Ditto
