Old 06-16-2020, 05:27 PM   #1
philipswanson
Default Greasing the Front U Joint
Since I have the driveshaft out and apart on my 40 wagon, I am wondering how the U Joint gets any grease when the fitting on its outer shell just allows grease to go external to the joint. It doesn't seem like this would allow any grease to reach the joint, only to splash around outside of it. Is there a way to actually get grease into the joint itself without pulling the transmission?
philipswanson is offline   Reply With Quote
Old 06-16-2020, 06:25 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Greasing the Front U Joint
As you may surmise, there is a hole right behind the zerk grease fitting on the bottom of the clamshell that allows grease to enter the internal area where the U-joint is located. When you literally squirt enough grease into the fitting grease will be forced thru that hole.
That's why you literally fill the clam shell with grease. I think I used about 2 cartridges of corn head grease and stopped when I saw I coming out near the speedo gear. I also used the newer style clamshell o-ring seal instead of the OEM cork style.
https://www.ebay.com/itm/Ford-flathe...QAAMXQTghRXOy6
19Fordy is online now   Reply With Quote
Old 06-16-2020, 06:53 PM   #3
philipswanson
Thanks for the information. I will have the driveshaft back in before I get that new seal so I guess I will have to slit the blue seal and gasket to get it in. Hope that will work.
Is it possible to remove the grease fitting and line up the hole on the U joint and shoot the grease directly in the U joint area without filling the whole shell?
Old 06-16-2020, 07:00 PM   #4
Talkwrench
Talkwrench's Avatar
Oil also migrates from the open bearing at the back of the trans. If a uni runs completely dry the chances are the oil baffle is hard up against the bearing in the trans. I check this when rebuilding. There should be a very small gap when done up. No need to go overboard with the greasing its not that big an area, 1/2 a decent cup full of semi fluid grease should be plenty.
File Type: jpg 14202532_10154490527838064_6368380684215240943_n.jpg (35.9 KB, 68 views)
Old 06-16-2020, 10:37 PM   #5
19Fordy
19Fordy's Avatar
I suppose it could be done if you have a thin nozzle on your grease gun. Or you could pack the U-joint by hand before you install it.
Talkwrench makes some good points. That migration of gear oil from the transmission is very critical Also, the blue seal is not one piece. You cut it to fit and it fits together end to end.
Old 06-21-2020, 12:41 PM   #6
philipswanson
I have the shell and driveshaft off. Is there a way to pump grease directly into the needle bearings instead of just filling the surrounding are? I can't figure out how the needle bearings and trunnions get grease that way. Seems like it would just lubricate the outside of the joint.
Old 06-21-2020, 12:51 PM   #7
Will D
Will D's Avatar
If using cornhead grease, it becomes liquid with low heat and will reach the bearings easily. I would still pack the bearing with cornhead before installing.
Will D is offline   Reply With Quote
Old 06-21-2020, 12:57 PM   #8
philipswanson
Where I n the heck do you find Cornhead grease? Never saw it in our stores.
Old 06-21-2020, 12:58 PM   #9
Will D
Will D's Avatar
There is multiple threads on u joint grease if you do a search. Some guys install the clam with the grease fitting at the top instead of bottom and remove it like a cap to pour in same oil as they use in the trans.... with all new seals it should stay in there. Personally I use cornhead grease....
Old 06-21-2020, 12:58 PM   #10
Will D
Will D's Avatar
John Deere or any tractor supply store.
Old 06-21-2020, 12:59 PM   #11
Mart
Mart's Avatar
Does your UJ have needle bearings? The stock Ford ones have bushings.
Mart is online now   Reply With Quote
Old 06-21-2020, 01:04 PM   #12
Will D
Will D's Avatar
Mart is right. When you mentioned needle bearing I thought you were referring to the front driveshaft bearing that sits just after the UJ which shares the same lubrication chamber.
Old 06-21-2020, 01:04 PM   #13
Lawson Cox
Lawson Cox's Avatar
Most any John Deer tractor place should have it.
Old 06-21-2020, 02:46 PM   #14
19Fordy
19Fordy's Avatar
You can get CH Grease here: Buy 2.
https://greenfarmparts.com/shop/john...kaAnQ5EALw_wcB
Old 06-21-2020, 03:16 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Three John Deere dealers closest to you:
John Deere, 1073 N. Marshall Ave., El Cajon 92020 619-448-2855
John Deere Landscapes, 819 Anita St., Chula Vista 91911 619-423-9060
John Deere Landscapes, 751 Design St., Chula Vista 91911 619-421-7627
__________________________________________________ _______
Pack that U-joint (use GREEN JD Cornhead Grease) like in this picture.
Click Links Below __
T5 W/TORQUE TUBE
Old 06-21-2020, 05:08 PM   #16
J Franklin
J Franklin's Avatar
So that's why I stop at green lights!
Old 06-21-2020, 05:21 PM   #17
40cpe
40cpe's Avatar
A little off subject, but I have used that red Mystik grease in the alemites of my tractors, etc, that aren't used a lot. I have found that if they aren't greased regularly, the grease dries and is very hard to get the grease to flowing again. I've switched to a moly type grease hoping for better results.
Old 06-21-2020, 05:23 PM   #18
19Fordy
19Fordy's Avatar
Ouch!
Old 06-21-2020, 06:08 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 19Fordy View Post
Ouch!
"OUCH" what? DD
T5 W/TORQUE TUBE
