Old 06-02-2020, 10:36 AM   #1
DNLs1930
DNLs1930's Avatar
Default Spark advance
Ok all you experienced A Modelers I need some understanding of the effects of advancing the throttle and power causing overheating...
Finally got the car started after a steering box leak fix, installing a 6 V Alt, fixing the brake rod contact area for the brake light switch, soundproofing/heat shielding the car and reinstalling the 12v power supply and CB radio....
As the car was idling and after the initial increase in RPM to "start" the Alt charging I was trying different settings for both the fuel and spark advance. The fuel is simple more fuel RPM increases less fuel RPM decreases.
Spark though is a totally different thing. With the spark retarded (up) the idle lopes or sounds like a Model A with it advanced (down) 3-4 notches it hums like a sewing machine. (smooth idle) my question is the smooth idle where you want to be or why is the loping "Model A" idle the norm?
Will the car warm up faster with the throttle advanced or should it just lope until warmed up.
THANKS for teaching me new things about these awesome cars!!
DNLs1930 is offline   Reply With Quote
Old 06-02-2020, 10:51 AM   #2
wmws
Default Re: Spark advance
Have your advance down where it hums as you say. The retarded idle is just a Model A thing where we all think it sounds cool, real slow and a little lumpy. For warm up just a little more RPM than at idle, in the hum position, lever down a few clicks.
wmws is offline   Reply With Quote
Old 06-02-2020, 11:14 AM   #3
redmodelt
redmodelt's Avatar
Personally I want my engines to hum, purr not lope! I think it is hard on the power train, each time the pistons come up, running too slow they stop before the flywheel carries them over and spark comes after TDC, I want that to be as smooth as I can make it. I think it is a dumb carry over from people that want to show just how slow the motor will run and in my OP has no place in the real world.
Old 06-02-2020, 11:37 AM   #4
30 Closed Cab PU
The only time the spark lever should be full up is when starting, and immediately then pushed down about 1/4s down its travel for warm up and very low speeds. Use the Model A Ford Instruction manual for spark/GAV settings.
Old 06-02-2020, 12:10 PM   #5
Patrick L.
Patrick L.'s Avatar
I'm not sure what you mean when you say fuel. I think you are talking about the right lever which is the throttle lever. Left lever is spark lever.
Left up, right down a bit for starting
Once started left down about half
right lever up once warm enough, left down 1/2 to 3/4 for most running.
most overheating happens because of retarded timing.
Old 06-02-2020, 01:12 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I agree that retarded timing is the main cause of over heating . Ford said full advance at speed . I fully retard the spark lever when starting the engine . I run full advance at speed . I feel that anywhere from 35 MPH on up would have been considered speed back in the day . At low speed I retard the spark as necessary to prevent timing knocks and bucking . It should be easy to tell when running too slow for the gear that is being used . Luging the engine at low speed is very bad for the babbit . Slightly retarding the spark at low speeds has worked well for me for the past 60 years .
Old 06-02-2020, 10:36 PM   #7
DNLs1930
DNLs1930's Avatar
Originally Posted by wmws View Post
... The retarded idle is just a Model A thing where we all think it sounds cool, real slow and a little lumpy. For warm up just a little more RPM than at idle, in the hum position, lever down a few clicks.
Thanks if you always hear them "loping" then that is the "normal" condition.
Originally Posted by Patrick L. View Post
I'm not sure what you mean when you say fuel. ...
Yes the "fuel" I'm referring to is the lever on the right or as I call it 1930 cruz control. And thanks the overheating is the part I was more interested in.
Originally Posted by Purdy Swoft View Post
I agree that retarded timing is the main cause of over heating . ...
Thanks
Idid read the owners manual and start full retarded and some throttle but needed to know the loping is not the best way as well as get a better understanding of the retard/advance for the spark control. When I'm driving I do have hte spark advanced and going up hills it really seems to gives a booost.
Old 06-03-2020, 08:13 AM   #8
Dave in MN
Dave in MN's Avatar
DNLs1930'
"I did read the owners manual and start full retarded and some throttle but needed to know the loping is not the best way as well as get a better understanding of the retard/advance for the spark control. When I'm driving I do have hte spark advanced and going up hills it really seems to gives a booost." [/QUOTE]
Your last comment about having the spark advanced and going up hills it really seems to give it a boost.
I am not sure I understand what you mean by that part of the ststement so I would like to add the following comment:
When you climb hills and the engine is pulling hard, the spark should be retarded (left lever up some) to eliminate knocking and lessen the high pressures in the main and rod bearings. Two notches is typically enough. When you have reached the top of the hill and the car is mostly back to speed, return the left lever down two notches and continue on your way.
Good Day!
Dave in MN is offline   Reply With Quote
Old 06-03-2020, 08:22 AM   #9
Patrick L.
Patrick L.'s Avatar
Thanks
Cruz control Yep, thats one way to look at it !
Where ever you have the spark lever set, if you start to hear the engine knock/ ping/ detonate, then quickly push the left lever up a few clicks to stop that knock. An engine can handle some detonation with no damage but it sure doesn't do it any good.
Old 06-03-2020, 09:54 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
My use of the spark advance lever:
File Type: jpg Spark Advance Lever Operating Positions.jpg (61.6 KB, 151 views)
Bob Bidonde
Old 06-03-2020, 11:22 AM   #11
DNLs1930
DNLs1930's Avatar
Good Day!
I would guess the "boost statement" is based on the fact I have been running the advance as taught which was about 1/2-3/4s advanced which when at speed and going up a hill I would advance it a little more and the car would smooth out seem to have a bit more power. The biggest hill we have locally is not that big but I do end up retarding the advance as I get closer to the top which I would guess coincides with the loading of the engine. I have net experienced knocking or detonation so I must be doing something right without really knowing it... Thanks for the lessons.
Old 06-03-2020, 11:25 AM   #12
DNLs1930
DNLs1930's Avatar
Got it and I do retard the spark as the engine loads up I just did not realize that it is the right way to drive the car. I just listen to the engine and move stuff around to make it smoother (not really but kinda) Now if I could just learn to down shift...
Old 06-03-2020, 02:55 PM   #13
Patrick L.
Patrick L.'s Avatar
smoother, yep. The car will tell you, feel what its doing.
Downshifting. It'll come. Raise the engine speed more than you think you need. Better it be too high than too low.[ especially from 2nd to first.]
Old 06-03-2020, 10:30 PM   #14
Aok
Aok's Avatar
Nice drawing easy to remember.
Aok is offline   Reply With Quote
Old 06-03-2020, 10:43 PM   #15
GerryAllen
Enjoyed the discussion. I know from our club meetings everyone has a theory.
This discussion cleared up some misconceptions I had.
Gerry Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 06-04-2020, 08:33 AM   #16
ryanheacox
ryanheacox's Avatar
Great illustration. Makes me think I may be keeping the spark too far retarded even with the 5.5 head.
Old 06-04-2020, 08:50 AM   #17
Bob Bidonde
My philosophy is to give the Model "A" and the Model "B" all of the timing advance they will take without knocking. Doing so, the engine makes more torque and power. I find cleaner spark plugs and cleaner combustion chambers result.
Bob Bidonde
Old 06-04-2020, 08:58 AM   #18
Purdy Swoft
Same here !!!
Old 06-04-2020, 09:30 AM   #19
Greg Jones
Greg Jones's Avatar
I agree with Bob Bidonde and Purdy, you need to get as much advance as possible to get maximum performance. Too much advance robs performance. Proper advance is kinda specific to your engine's setup. High compression head? What is your point gap? Are you really timed correctly? Lots of other variables. I have two engines for which I am responsible for the care and feeding of. Basically all stock except for the cylinder heads: On the one I have a 5:5 head, with stock Zenith carb, stock distributor with points set to 0.020" I can advance about two-thirds for high-speed driving. My other engine has a 6:1 head, also with stock Zenith carb, stock distributor with points set to 0.020". The 6:1 won't take quite as much advance-I call it "5/8 advance" or just a little over halfway. At this setting it runs at 50mph nice and pretty all day long. Once I find the sweet spot I rarely move the advance lever but will if going uphill or at low low speed or a combination of both. Most of the time, I can take a gentle hill just by giving it more gas and can pick up speed going uphill. I say all this to point out that a lot depends on whether you run a stock head or a high(er) compression cylinder head.
Greg Jones is offline   Reply With Quote
Old 06-04-2020, 09:48 AM   #20
30 Closed Cab PU
Personally with my A timed correctly have been unable to hear knocking/pinging, including full advance on hills, but still retard the lever on hills as a safe guard. Rebuilt motor with standard head, 87 octane ethanol free.
Have wondered if on the standard head it is not as much as a problem since the A was designed in the 20s when octane was lucky to be rated at 50. Now it is 87 or above.
What do you think?
