Old 05-23-2020, 12:36 PM   #41
shew01
shew01's Avatar
Default Re: What are some of the counter intuitive things you have learned about a Model A?
Originally Posted by Jack Shaft View Post
If you have an aluminum high compression head it's highly advisable to use anti seize on the spark plug threads.
That's a good point. I updated "19)" in post #1.
Old 05-23-2020, 10:00 PM   #42
daren007
Brent said it all.
daren007 is offline   Reply With Quote
Old 05-23-2020, 10:13 PM   #43
Jack Shaft
Anti sieze thread compound is a very useful anti galling thread lubricant,it also works to keep distributor housings from rusting to the heads.It also works well on clevis pins,especially ones removed for maintenance,like the clutch linkage pin,a mixture of anti seize and engine oil makes a 'paintable' lubricant good for the wishbone ball..Its a good idea to use it on assemblies subject to weather as well,if a bolt and nut can rust neversieze it..takes a bit longer to assemble the job,but the next time you...or the next guy does it he will thank you.
Old 05-24-2020, 12:25 AM   #44
cpf240
cpf240's Avatar
Engines were stamped when they passed testing. The number on the engine was stamped on the frame when the engine was installed.
Read Steve Pluckers study on this process. http://www.plucks329s.org/studies/studies.htm
cpf240 is offline   Reply With Quote
Old 05-24-2020, 03:40 AM   #45
woofa.express
woofa.express's Avatar
Originally Posted by BRENT in 10-uh-C View Post
Expound on your opinion regarding that, please.
I reckon many A owners add 10 mph or more to the max speed their motor cars achieve. Mine won't hold a candle to speeds that are quoted. hope that explanation suffices. cheers, gary
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 05-24-2020, 03:43 AM   #46
woofa.express
Originally Posted by 40 Deluxe View Post
But don't most GPS units use a female voice?
The GPS has saved my marriage many times
I know many things,
Old 05-24-2020, 06:22 AM   #47
shew01
shew01's Avatar
I added "20)" for rear brake drums.
Old 05-24-2020, 06:30 AM   #48
shew01
shew01's Avatar
Thanks for the feedback. I updated "5)" in post #1.
That is a very good link. Thanks for sharing.
Old 05-26-2020, 07:13 AM   #49
30 Closed Cab PU
Shew01, correction from cpf240 - Sorry for my error item 5, post 31. Correct is the frame was stamped to match the motor # at time of motor install.
Old 05-27-2020, 07:15 AM   #50
Bill Pursel
Bill Pursel's Avatar
I run mine 3/4 to 7/8 down the quad all the time ...in town and hiway runs great.
Bill Pursel is offline   Reply With Quote
Old 05-27-2020, 10:16 AM   #51
monto
monto's Avatar
Shew:- Bibliography for your perusal....
MODEL A FORD MECHANICS HANDBOOK
Les Andrews
MODEL A FORD CONSTRUCTION, OPERATION AND REPAIR
Victor W Page Post Motor Books
FORD OWNERS HANDBOOK OF REPAIR & MAINTENANCE
Victor Page Floyd Clymer Publications
MODEL A FORD RESTORATION HANDBOOK
Gordon Hopper Floyd Clymer Publ
KNOW YOUR MODEL A FORD
Murray Fahnestock Page Motor Books
'30 Coupe
monto is offline   Reply With Quote
Old 05-27-2020, 04:51 PM   #52
CHuDWah
CHuDWah's Avatar
..5) The Model A does not have a VIN (Vehicle Identification Number), in terms of what we call a VIN on modern cars...
...For example, the Model-A DID have a VIN. The acronym VIN is short for the words Vehicle Identification Number, ...
Well, yes and no. The Model A did NOT have a VIN (Vehicle Identification Number) as such. Per the Instruction Book:
The engine number is also the serial number of the car.
The engine number is analogous to the VIN in that it identifies a particular car. But it has a different format and Ford called it the "serial number."
CHuDWah is offline   Reply With Quote
Old 05-27-2020, 06:34 PM   #53
Bill G
Bill G's Avatar
I have learned that I will never find all the rattles and squeaks! My wife says to quit looking. "After all, it's 91 years old!"
Old 05-27-2020, 07:38 PM   #54
shew01
shew01's Avatar
Jack,
Good idea. I updated "19)" in post #1.
Old 05-27-2020, 07:40 PM   #55
shew01
shew01's Avatar
I added "21)" to post #1 for rear wheel bearing grease seals. The ideas came from a couple of barners that guided me along.
Old 05-27-2020, 07:44 PM   #56
shew01
shew01's Avatar
Would you mind taking another look at "5)" in post #1? If it needs tweaked, please let me know.
Old 05-27-2020, 07:51 PM   #57
shew01
shew01's Avatar
There seems to be some disagreement about exact settings for the spark lever, the throttle lever, and the GAV. I added the following to the bottom of "7)" in post #1.
"Apparently, the settings for the spark lever, the throttle lever, and the GAV (Gas Adjustment Valve) vary quite a bit from car to car, and these settings appear to be an "art form," rather than an exact science. Folks tend make strong arguments for the settings that they have found to work for them."
I am open to re-wording if you can come up with something better.
Old 05-27-2020, 07:55 PM   #58
shew01
shew01's Avatar
Les Andrews
Thanks. I updated "9)" in post #1.
Old 05-27-2020, 07:58 PM   #59
shew01
shew01's Avatar
Thanks. I updated "5)" in post #1.
Old 05-31-2020, 07:18 AM   #60
dumb person
dumb person's Avatar
Perfection.
It's a very precise machine, but not required to be as precise in most circumstance.
Originally Posted by katy View Post
I'm that guy. I self taught myself to drive a Model T when I was 16 years old. I bought a model T coupe for $25 and didn't know or have access to anyone that knew anything about model Ts. I read a book "Tin Lizzie" about model Ts and in it it explained how to drive one, so that's what I did. Sold my last Model T about a month ago.
Taught myself to drive one of those when i was 12.
Didn't have access to the car. Just a book describing it.
2 things i didn't get 100% perfect when i did access the car was pushing the clutch peddle all the way down when trying to stop. 1.4 seconds later that habit stopped.
The other was learning how much advance was required at speed. Turns out the car was lenient than i thought.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
