Old 05-15-2020, 07:18 PM   #1
1crosscut
1crosscut's Avatar
Default King pin spacers
In reading Les Andrews red book and other comments on threads relating to adding spacers under the thrust bearings the general advice is you are supposed to add enough of them to eliminate any gap. So would anyone be able to shed just a bit more light on the specifics of how they decide if it will require one, two or more spacers?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-15-2020, 08:27 PM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: King pin spacers
The purpose of the spacers is to shift all the load on to the thrust bearing so there is no load on the spindle between the lower pin bore and the axle. The usual practice is to add shims under the bearing until the bearing can no longer be rotated by hand when an upthrust is placed on the spindle axle shaft. There should be a small gap between the lower spindle bore surface and the axle. If not done correctly stearing will require more effort and wear will occur at the spindle/axle contact surfaces. HTH
Mulletwagon is offline   Reply With Quote
Old 05-15-2020, 08:44 PM   #3
chrs1961815
chrs1961815's Avatar
The reproduction bearings are the reason why shims are needed as they are too thin. I have a few sets of NOS ones so I ended up using them with no shims.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-15-2020, 09:11 PM   #4
Tom Endy
Tom Endy's Avatar
See attached document.
Tom Endy
Old 05-15-2020, 10:37 PM   #5
1crosscut
1crosscut's Avatar
Great information gents. Most appreciated.
Old 05-16-2020, 06:48 AM   #6
1931 flamingo
1931 flamingo's Avatar
I remember shims being included with king pins back in the sixties.
Paul in CT
Old 05-16-2020, 08:05 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
If the roller bearing is not supporting the vertical forces, the king pin lock bolt and its hole in the axle take a beating.
Bob Bidonde
Old 05-17-2020, 06:24 AM   #8
David R.
I found some shims from Rock Auto when I did my AA king pins. They are larger than A king pins on the ‘30. I used original thrust bearings but still needed .010” to 020” shim. Got a pack of 20 that were .005”.
David R. is offline   Reply With Quote
Old 07-31-2020, 07:59 PM   #9
aermotor
Little confusing for my ageing brain. Am I correct that on checking previously installed king pins with the car weight on the ground am I good with a gap above and below the spindle and axel, and the bearing will not rotate by hand?
John
aermotor is offline   Reply With Quote
Old 07-31-2020, 08:49 PM   #10
Mulletwagon
Recommend minimum gap above the spindle since excessive gap will allow the spindle assembly to translate vertically. Might jack up the front end under the axle and then see if you have vertical play on the wheel. The effect of excessive gap will be obvious.
Old 08-01-2020, 10:13 AM   #11
Bob C
Any chance you have a part number, I did a search at Rock for .005 shims
but didn't get any hits.
