#21 |
Because I read the news, along with some basic tools and some extra parts.
Don't leave home without it.........
#22 |
I really think the canvas tool roll is the berries. Bucket boss has the expensive ones, but there are good ones for less than $10. Unroll it and you have all your tools.
#23 |
When we are on a long trip, we are usually outside phone range so I have to expect that if the car stops, I am the one who will have to get it going. I carry a set of tools (spanners, screw drivers, pliers etc,, jack and handle. There is a distributor and carburettor (never have needed either), some electrical wire, fan belt and test light. A spare tube (from when we couldn't get a decent one) is always there and a stick of Kneedit (an epoxy putty).
Because a repair might take a while, we have a toilet roll, food and water. We have had to make some what I think are clever improvisations but we've always gotten home. IMO, the best thing to take is the gap between your ears filled with knowledge about your car.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#24 | |
![]() Quote:
Yes things can happen, but they can happen on a modern also. I'm certainly not going to let it spoil my fun. That said, I do carry a small tool box, Halotron fire extinguisher and a first aid kit 'just in case'. Last edited by Y-Blockhead; 04-28-2020 at 11:38 AM. |
#25 |
Fan belt? Carburetor? Ok now how many of you have ever needed either one. I carry a screwdriver.
#26 | |
The belt, was after replacing the fan belt as part of "good maintenance". Did it while I had the radiator off, why not, I was there. Threw the take off under the seat. The new one separated about 30 miles from home, ( about a month old, maybe a hundred miles on it.) Put the take off back on and drove home. Sent from my E6810 using Tapatalk |
#27 |
I run my 190A out of state to New England Meets, and here is what I carry onboard. 99% of this stuff fits in the front tool box shown in the photo:
Abrasive Paper Axle Hub Gasket (2) Axle Keys (2) Blanket Cable Ties Clamp (2) Coil 12V, Internal Resistor Coil Hi-V Wire Condenser OEM Condenser, Modern Cotter Pin Pick Crank & Lug Nut Wrench Crimper, Wire Terminal Cylinder Head Eye Bolts (2) Distributor, Rebuilt Drum Puller Extension 3/8 x 3” Extension 3/8 x 6” Feeler Gage File Rat Tail Flashlight, LED Float Valve Shim Set Garmin GPS Gasket Paper Gasket Scraper Gasket “A” Water Pump Gasket “B” Water Pump Gasket, Cylinder Head Gloves Grease Grease, Dielectric Hammer, Ball Peen Hardware Assortment Ignition Point Posts (2) Ignition Point Set, OEM Ignition Point Set, Modern Insurance Policy Jack & Handle Knife, Utility Magnet, Telescoping Marker, Black Sharpie Mirror Motor Oil 10W30, Quart Multimeter Nut Drivers 3/16, 1/4, 5/16 Nut Drivers 11/32, 3/8 Nut Drivers 7/16, ½ Paint Brush 2” Pin, Valve Stem Pliers, Slip Joint Pliers, Diagonal Pliers Visegrip 7” Pliers, Water Pump Putty Knife Rags, Several Ratchet 3/8 Drive x 6” Ratchet, Swivel Head Registration & Insurance Rod, Plastic Rope, 32” RTV Silicone, Tube Seal, Rear Wheel Bearing Scissors Scotchbrite Cloth Screw Driver, Offset Screw Driver, Phillips Screw Driver w Holder 1/8 Screw Driver 1/4 Screw Driver 1/4, Short Screw Driver 5/16 Screw Driver, Large Shims, Rear Axle (2) Socket Adapter 1/4 - 3/8 Socket Adapter 3/8 – 1/2 Socket Adapter 1/2 - 3/8 Socket 3/8 Dr x 1/2 Socket 3/8 Dr x 7/16 Socket 3/8 Dr x 1/2 Socket 3/8 Dr x 9/16 Socket 3/8 Dr x 5/8 Socket 3/8 Dr x 11/16 Socket 3/8 Dr x 3/4 Socket, Timing Gear Nut Spark Plug TT10 Spark Plug Gap Tool Stop Leak, Barr’s Tape, Electrical Tape, Duct Test Light, Coil Test Light, Hi-Voltage Rain-X Rotor Timing Gear Timing Pin w Key Ring Tire Irons (3) Tire Pressure Gage Tube Patch Kit Tube Valve Service Tool Tube Valve Puller Tooth Brush Towels, Microfiber (3) Towel, Terrycloth Valve Guide Driver Water, 1 Gallon Water Pump, “A” Wheel Bearing Set, Front Wheel Bearing, Rear Wire AWG 16 x 24” Wire Brush Wire Hangar Wire Strippers Wrench, Adjustable 4” Wrench, adjustable 10” Wrench 1/4 Wrench 3/8 Wrench 7/16 Wrench 1/2 Wrench 9/16 Wrench 5/8 Wrench 11/16 Wrench 3/4 Wrench, Carburetor Jets Wrench Set, Allen Wrench, Nu Rex Timing
Bob Bidonde Last edited by Bob Bidonde; 04-27-2020 at 08:05 AM. |
#28 |
Are you serious?
#29 |
ammo
#30 |
I think Bob is being facetious. Looking at his list, several of his items are duplicates or combined with another item.
#31 |
B]That is the funniest, most outrageous post I have ever seen! Hopefully after he gets his laughs he will send us his real list! Hahaha[/B]
#32 |
I did notice all that and no fan belt.
#33 |
Bob needs to add a couple of fuses and or circuit breakers, fire extinguisher, first aide kit and a fan belt. Maybe a trailer hitch and trailer... to tow the spare Model A.
The Master Cylinder Enjoying life at the beach in SoCal... |
#34 |
When on a trip with other As, sure would be happy if I broke down and someone like Bob was with. More fun to quick fix and be on my way instead of ending my day waiting for a tow truck.
#35 |
Bob is definitely the guy we all want to be cruising with us. He should eat free at all the stops.
#36 |
#37 |
The usual plus a bottle of aspirins, a few nitro tablets and a wire cutters.
The jack, spare tire, tool bag should go without mention. A roll of paper towels can be handy too. |
#38 |
The jack, spare tire, tool bag should go without mention. A roll of paper towels, as already suggested, can de handy. Did anybody mention dry hand cleaner? |
#39 | ||
I should have a tire pump and fan belt, but i can't find a tire pump anywhere. And anyone under 50 seems to be "What's a V belt?".
I do tend to carry a tiny bottle of oil. Swiss army knife, screwdriver or 2. adjustable spanner. And lately i've been reminded of the value of a packet of chewing gum. Can patch all sorts of leaks with that. Also, a candle and piece of soap. Amazing what you can lube or patch with those. A stick that you can carve threads into with a pocket knife is handy if you lose a sump plug too. Quote:
This is not to be underestimated. If more people did this (regardless of what brand car they drive), there'd be a lot less break downs in the first place.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
#40 |
Bob made a nice post, but I'm curious, I see masking tape in the bag but not on the list? Also, where's the head gasket? I didn't see it on the list or in the picture?
Something I try to do, is carry proven ignition parts. As in not buying new ones for the road kit. I'll do a tune up when the car is running fine, polish the points, and carry those. Nothing more aggravating than defective new parts. Except digging through all the junk I carry trying to find said parts. Anybody carry road flares? Or reflectors? Sent from my E6810 using Tapatalk Last edited by Blue-Truck-Nut; 04-28-2020 at 03:59 AM. |
