Is the Emergency Brake Lever to Cross Shaft Rod Assembly, A-2853, on the Mid 1928-Mid 1929 vehicles with Emergency Brake Lever in front of the gear shift and where it attaches to the Emergency Brake Cross Shaft Rod Assembly, slightly bent to the right or left depending on which way you look at it if it was installed? OR is it a perty much stright rod?
Thanks. Pluck |
'29 Special Coupe for my example Pluck, May 1929 for production time-frame.
The rod that you reference is straight. E Brake handle is in front of the shifter.. kb |
Pluck |
