Old 04-03-2020, 07:11 PM   #1
mach0415
mach0415's Avatar
Default 1928 Canadian Tudor
Hello all. I recently bought what seems to be a mostly original 1928 Canadian Tudor. It has a black Ford radiator shell emblem, square screw heads, and Ford script bumper clamp bolts only on the rear. The fronts are smooth. As I was checking things out, I checked the engine number and see that it’s what appears to be “F88-27“
It seems that Canadian A’s that had and “F” in the engine number would have had an “AF”XXXX And they would have been designated as RHD, based upon my research. Does anyone have any info as to why it is stamped differently? Could it be that someone removed the original stamp and re-stamped it?
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 04-03-2020, 07:44 PM   #2
Synchro909
Synchro909's Avatar
Default Re: 1928 Canadian Tudor
That doesn't look like a factory stamp to me-more like it was done in someone's back yard. My understanding of Canadian engine numbering is that they start with a "C", then a number similar to what was used in the US. Eg, CA XXXX but the cars that came here had three letters before four digits. CAD XXXX, CAQ XXXX etc.
I've never seen or heard of a number like the one on that engine.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Synchro909 is online now   Reply With Quote
Old 04-03-2020, 08:17 PM   #3
updraught
updraught's Avatar
You prompted me to look up a Canadian engine number I just found on an original registration document for a car my father bought in 1956. It is CA84604 (which seems to be January 1929 manufacture).
Found while cleaning out junk in our, so called "office", for a now at home worker yesterday.
http://www.fordgarage.com/pages/ABenginenumbers.htm#C5
Our Geelong Ford factory was owned by Ford of Canada.
This vehicle, on the document, says it is 1930 year of manufacture, vehicle number 4390, and was first registered on 15th December 1932.
updraught is offline   Reply With Quote
Old 04-03-2020, 08:25 PM   #4
chrs1961815
chrs1961815's Avatar
I think it was restamped at one point. Factory stamps produced a nice straight number -all numbers were pretty much straight across. Yours is kind of up and down.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-03-2020, 08:51 PM   #5
mach0415
mach0415's Avatar
Yeah that’s what I was thinking too. I am wondering if since many Canadian A’s do not have a chassis stamp, depending on the equivalent to DMV office in the US, if Canada assigns a “VIN” of their own and stamped accordingly. I was told that the engine was rebuilt in the 1990s but I ha e not gotten as far as opening it up to see what’s what. Thanks
Thanks,
Mark in SC
Old 04-04-2020, 12:16 PM   #6
Steve Plucker
What is the length of the engine pad?
Pluck
Old 04-04-2020, 10:26 PM   #7
mach0415
mach0415's Avatar
Thanks Steve. It looks to be 3 1/4”
Thanks,
Mark in SC
Old 04-05-2020, 12:15 AM   #8
Steve Plucker
Ford started using that size about February 1, 1929.
Pluck
Old 04-05-2020, 12:56 AM   #9
Tudortomnz
Tudortomnz's Avatar
That is a re stamp, not a Ford Canada engine number. All engines stamped CA ...... up to 150,000 which was end of Aug. '29. From then on CAQ; CAW;CAE etc ending in CAD in Feb '32. These 3 digit blocks were in 10,000 batches.
No blocks were stamped with an F [ as in CAF] but some US blocks for export cars were. Ford US exported a large quantity of RHD vehicles to mostly Sth America, more than Canada RHD to British Commonwealth countries.
The Robertson bottom screw in your dash is incorrect size ; should be as the top one. Cheers.
Tudortomnz is offline   Reply With Quote
Old 04-05-2020, 08:35 AM   #10
Chris in WNC
Chris in WNC's Avatar
restamped.
every factory serial number I've seen was very tidy, not a haphazard mess like this number.
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 04-05-2020, 11:11 AM   #11
mach0415
mach0415's Avatar
Thanks for all the comments. Yeah it would appear it’s definitely a re-stamp and all the factory ones I’ve seen are straight as well. Thanks for the heads up on the screw too.
Thanks,
Mark in SC
Old 04-05-2020, 11:22 AM   #12
Jim Brierley
Cars built in Canada, for Canada, were left-hand drive.
Old 04-05-2020, 06:03 PM   #13
updraught
updraught's Avatar
Ours were knock down, so I guess the workers didn't have to jump from one side of the assembly line to the other.
Old 04-06-2020, 04:12 AM   #14
Dave Slater
Dave Slater's Avatar
Not all cars assembled in Canada were Left Hand Drive, some were Right Hand Drive.
Dave Slater is offline   Reply With Quote
Old 04-06-2020, 07:46 AM   #15
updraught
updraught's Avatar
Ah, so they did have to jump from one side of the assembly line to the other.
Old 04-06-2020, 08:04 PM   #16
Tinbasher
Tinbasher's Avatar
Here a list of the Canadian Engine numbers. Hope it helps. JP
Tinbasher is offline   Reply With Quote
Old 05-10-2020, 06:15 PM   #17
mach0415
mach0415's Avatar
I noticed the distributor bolt is missing and upon further inspection, realized the cast boss is broken off at the top and side of the head. So as I began to research replacement cylinder heads, I realized that the head is a Ford script USA service replacement. With all this in mind, I began to put 2 and 2 together as I read over Vince Falter’s Diamond engine info on fordgarage.com. Sure enough! It has a diamond near the timing gear inspection cover and casting number L121 or L127 near the valve cover. So it appears this is a diamond service engine with a December 12, 1937 or 1941 (cannot make out which year exactly). This would explain the apparent blank engine serial number pad and wonky number stamped after the fact. It has .020" over pistons from a more recent rebuild with the crosshatch still visible in the cylinder walls.
Thanks,
Mark in SC
Old 05-10-2020, 06:53 PM   #18
mach0415
mach0415's Avatar
Here are some pics of what I found to lead to the conclusion I did. Also, I am wondering if anyone knows what the S and B stampings in the block deck surface may indicate...
Thanks,
Mark in SC
Old 05-10-2020, 06:56 PM   #19
chrs1961815
The s and b stampings I have seen on various gasket surfaces on Model A engines as well. I think it just might be a casting number or foundry mark.
