Old 03-31-2020, 08:12 PM   #1
Mike A Model
Mike A Model's Avatar
Default 8BA Truck Motor - Oil
Recently I acquired a 1930 Roadster, that has been stored for some time, with an 8BA truck motor. As I go through the process of sorting thru the different systems. Two questions, I would like to ask concerning the general maintenance:
1. What oil would be recommended? I drained the oil and opened the oil pan inspection cover; the pan was very clean with no sludge buildup.
2. Being a truck motor how many quarts of oil? Currently, the engine does not have an oil filter.
Thank you for your help,
Mike
Mike A Model is offline   Reply With Quote
Old 03-31-2020, 09:14 PM   #2
alanwoodieman
Default Re: 8BA Truck Motor - Oil
most trucks have a 5 quart capacity plus one for an oil filter. I have several 8ba engines and I run 20w50 kendall oil in all of my flatheads . if you decide to put an oil filter back on be sure you have the 030 restrictor or you will have very low oil pressure. pm me if you want the oil filter can
Old 03-31-2020, 10:07 PM   #3
19Fordy
19Fordy's Avatar
I use 20W50 in my 8BA.
Old 04-01-2020, 01:13 AM   #4
earlyride
earlyride's Avatar
I'm running Lucas 10-30, has high zinc content
earlyride is offline   Reply With Quote
Old 04-01-2020, 08:05 AM   #5
alanwoodieman
20w50 Kendal is their racing/high performance oil and it has zinc
Old 04-01-2020, 08:17 AM   #6
Ol' Ron
Ol' Ron's Avatar
I think 10-30 would be the correct weight oil with stock bearing clearing clearances. Oil Pressure should be 10/15 lbs at idle and 40/50 at cruise. The reason is the lighter oil cools the bearing better than the heavier oils. However, the heavy oils make the driver and oil pressure gauge happier. Now the factory made industrial engines, that had a tag fitted to the block that stated the bearing clearance. Yes an old engine might need a heavier oil
Old 04-01-2020, 08:20 AM   #7
tubman
tubman's Avatar
Whatever is on sale at the Dollar General that has an API seal on it.
Old 04-01-2020, 08:41 AM   #8
Tim Ayers
I agree with this for a used motor. Remember, when this motor was new, they sold "recycled" oil. Any modern oil would seem like Champagne to this engine.
Old 04-01-2020, 10:05 AM   #9
51504bat
51504bat's Avatar
Before I rebuilt the 8ba in my '39 p/u I ran straight weight but after the rebuild I now run 20-50. Some people run diesel multi weight also. Its kind of up to you.
Old 04-01-2020, 11:38 AM   #10
flatheadmurre
flatheadmurre's Avatar
15-40 dieseloil...nothing fancy
Old 04-01-2020, 04:17 PM   #11
B-O-B
B-O-B's Avatar
using castrol 20-50 oil & if it is available 20-50 racing oil in my flat heads. One fresh 24 stud rebuild & one 21 stud pretty new rebuild & one 350 G M engine with plenty of miles on it,
B-O-B is offline   Reply With Quote
Old 04-02-2020, 05:54 AM   #12
Ol' Ron
Ol' Ron's Avatar
20/50 on a rebuild?????
Old 04-02-2020, 06:11 AM   #13
jetmek
Lotsa bad advice out there
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 04-02-2020, 07:39 AM   #14
alanwoodieman
run 10w30 for first 100 miles or engine stand run and then change to 20w50
Old 04-02-2020, 08:36 AM   #15
FortyNiner
FortyNiner's Avatar
For the great unwashed (that clearly includes me) a reference such as this is essential - Ford Flathead Engines: How to Rebuild and Modify by Tony Thacker and Mike Herman. 2016
Page 107: "Mike adds fresh engine oil to the [oil] pickup. His choice is Valvoline VR1 20-50; it aids in the pump's initial priming."
Is this incorrect?
Old 04-02-2020, 10:10 AM   #16
tubman
tubman's Avatar
That statement is unclear. Is he recommending that weight for general use, or for the initial run to facilitate oil pump priming? It seems to me to be the latter, but we can't be sure.
I run my engines on 10-30 or maybe 10-40 (whichever is cheaper). If the oil pressure is unsatisfactory, I would consider an increase in viscosity (or a rebuild).
Old 04-02-2020, 10:23 AM   #17
51504bat
51504bat's Avatar
Direct from the flathead experienced machinist who built the short block. Been several years and a couple of thousand miles and its still running like a top. Everyone has their own thoughts about oil but 20/50 works for me.
Old 04-02-2020, 02:07 PM   #18
leon bee
We don't really need another post here, but what the hell. I have two flatheads running, one completely rebuilt and another "freshened up". I used a 30wt breakin oil in each, and then went to NAPA 10w-30. Both engines have great oil pressure.
The thing is, I would not have considered the 10-30 except for Ol' Ron's posts since I came here to the Ford Barn.
leon bee is offline   Reply With Quote
Old 04-02-2020, 03:59 PM   #19
aussie merc
aussie merc's Avatar
first up fit a filter no filter = no chance of catching any thing that shouldnt be there Then talk to your oil supplier they will recomend the correct viscosity for your conditions. I might be wrong but it appears that every one has missed oil temp is actually what controls viscosity and oil life. you wouldnt run 20/50 in winter in northern canada as you wouldnt run 10/30 in saudi in summer as little as 10deg increase on a constant basis can half oil life. Castrol Texeco Shell it realy dosent matter they all have some smart people on there help lines
aussie merc is offline   Reply With Quote
Old 04-02-2020, 06:07 PM   #20
Bill OH
I run 5W20 in a 221 with Mellings oil pump - pressure is 35lbs at 170 deg F
Bill OH is offline   Reply With Quote
