Old 02-28-2020, 10:08 AM   #1
Oldbluoval
Oldbluoval's Avatar
Default 34 repo grill shells
I have a couple of 34 grill shells both NIB
I don’t have a 34 set up right now to see the fit
I’ve had these 20 years or better and they are not Drake; I believe they’re
Australian? Repos many years ago?
They are very nice with perfect plating very very nice looking
Can anyone shed light on the fit of these? Pros? Cons?
Thanks in advance
Old 02-28-2020, 10:16 AM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 34 repo grill shells
4 repro grilles that I know of...
1. Early replacement, fabricated, coarse bars and too few. Garbage.
2. V8 Shop. Tooling by Lyle Funk. Fairly nice but had some fitting issues on the hood corners.
3. Australian. Semi-hand made, quality varied grille to grille, could make a nice replacement.
4. Drake. Very nice.
None available.
Karl Wescott is offline   Reply With Quote
Old 02-28-2020, 10:18 AM   #3
deuce lover
deuce lover's Avatar
CW Moss in Orange was handling them(Australian) along with the 35's.Chad who now has the store might be able to give you some info on them.Number 1 that Karl is referring to might be the Argentina ones.Ford Obsolete brought those in the mid 1970"s? Australian ones looked much better.
Post close up pics of what you have if you can.
Old 02-28-2020, 10:32 AM   #4
35fordtn
35fordtn's Avatar
If you are refering to Chad Looney, he no longer owns CW Moss. Troy Williams owns it now.
I have a old V-8 Shop one and have comparatively fit it. The Drake Grille fit far superior to it, but even it had it's own issues
Old 02-28-2020, 10:52 AM   #5
deuce lover
Michael,Thanks. He must have stepped out after his dad passed.
Old 02-28-2020, 10:58 AM   #6
35fordtn
35fordtn's Avatar
I could be wrong, but I believe Chad inherited Vintique after his dad's passing and his brother acquired CW Moss, only to sell it to Troy (the original owner's son) shortly after for a hefty price.
I had spoken to Troy in recent weeks and he is really pushing to turn CW Moss into something big and attempting to do more than just stock Vintique stuff. From the looks of their website and new catalogs that appears to be the case. His positive attitude made it seem as though CW Moss will be a great place to buy from as a retail customer.
Old 02-28-2020, 11:42 AM   #7
deuce_roadster
deuce_roadster's Avatar
It has been my experience (1 34, 1 33) that fitting a FORD grille even to original Ford sheet metal (hood, inner fender panels, apron at bottom if grill) is not easy, it takes a lot of fooling around. I can't imagine it would be easier with a reproduction.
Old 02-28-2020, 12:09 PM   #8
RobR'35
RobR'35's Avatar
Curious~
How was the fit of these right off the line when assembled in the day?
When one watches the assembly in videos and such it seems laborless to the men. Though I do realize that one gets good with their job in repetition.
Still, there had to be variances in one from another in fit on assembled bodies.
RobR'35 is offline   Reply With Quote
Old 03-01-2020, 04:49 PM   #9
itslow
itslow's Avatar
Originally Posted by RobR'35 View Post
Curious~
I suspect that the Ford assembly line was far less picky about exacting fitment in 1933 and 1934 than those who are restoring the cars today.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 03-01-2020, 06:41 PM   #10
Graham Freeman
Are we just a little more picky with our restorations today as against when the vehicles were assembled in mass?
Graham Freeman is offline   Reply With Quote
Old 03-01-2020, 07:24 PM   #11
petehoovie
petehoovie's Avatar
https://cwmoss.com/collections/v8
Old 03-01-2020, 07:46 PM   #12
whizzernick
whizzernick's Avatar
why not look at an original ( untouched ) I have 66000 33 ford . I will post pictures. The fit is real good. I also have a 34 5-W that has never been apart. I will post pictures. The fit is also real good. My opinion is when we try to assemble a car with parts that did not come with it - or era replacement parts. OR cars that have been hit and repaired sometimes good and sometimes not so good. We have to work to get acceptable fits
whizzernick is offline   Reply With Quote
Old 03-02-2020, 06:11 PM   #13
JSeery
JSeery's Avatar
I would also think they knew all the tricks (places to adjust to get the result they were after).
Old 03-03-2020, 07:59 AM   #14
Oldbluoval
Oldbluoval's Avatar
Subject drift again.....
Has anyone fitted one of the older Australian grill shells?
They look absolutely superb....mine have been boxed for 15+ years
Thanks in advance (and arrears) for input
Old 03-03-2020, 11:00 AM   #15
johnboy34
Please put some pictures of it, I would like to check it out!
johnboy34 is offline   Reply With Quote
Old 03-03-2020, 11:42 AM   #16
Oldbluoval
Oldbluoval's Avatar
34 Grill pic. Got several views if you want to email direct ([email protected]). These are no longer available I understand nor are Drake's
Old 03-04-2020, 01:45 PM   #17
johnboy34
That does look good in the picture!
Did Ford grills have part numbers on them? If so where?
Old 03-04-2020, 03:01 PM   #18
Oldbluoval
Oldbluoval's Avatar
I have an original 33 and have had original 34 and not seen part # on them
Old 03-05-2020, 03:42 PM   #19
johnboy34
Thanks, I believe my 34 to be original and seen no number so I was curious.
Old 03-14-2020, 07:20 PM   #20
phil pavicich
I have fitted a few of the Australian repo grills made by Chris Nihill out of Bendigo Australia , they are really good quality and the fit up is almost perfect , when he makes them they are in raw finish unplated so you can trial fit tem before you plate them , i am very happy with mine
phil pavicich is offline   Reply With Quote
