Old 01-23-2020, 08:21 PM   #1
Randy1944
Randy1944's Avatar
Default Oil dipstick boss
I’m having no luck finding this part. Vanpelt shows it as part number 8BA-6751 for a 1951 flathead V8. It is the potmetal piece that is attached to the oil pan by three rivets. Any suggestions?
Randy1944 is offline   Reply With Quote
Old 01-23-2020, 09:08 PM   #2
johndee138
johndee138's Avatar
Default Re: Oil dipstick boss
One on eBay this evening from 3rd Gen Autimotive
johndee138 is offline   Reply With Quote
Old 01-23-2020, 10:01 PM   #3
JMFL36
JMFL36's Avatar
One caution. The holes in the bracket I got did not line up with the holes in my oil pan. I elected to drill a new hole in the bracket that lined up with the existing pan holes. You obviously need to drop the pan to install the bracket rivets. Make sure they are tightly secured so there are no leaks around the bracket gasket.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 01-23-2020, 11:09 PM   #4
tubman
tubman's Avatar
I believe "GOSFAST" on here has a plate that goes inside the pan that allows the dipstick boss to be attached positively with machine screws. It is probably something that should be considered.
Old 01-24-2020, 07:56 AM   #5
JMFL36
JMFL36's Avatar
Nice! Tack the plate to the inside of the pan and you'll never have to drop it again for future bracket issues. Wish I knew about it when I did mine.
Old 01-24-2020, 08:02 AM   #6
Randy1944
Randy1944's Avatar
I looked again on 3rd. Gen. and still missed one for a 51 v8.
Old 01-24-2020, 09:05 AM   #7
Tim Ayers
Call Fred @ Southside Obsolete. I'm sure he'll have a NOS one. He's barnfind08 here.
Old 01-24-2020, 09:30 AM   #8
GOSFAST
GOSFAST's Avatar
Hi Randy, P.M.'d you before, I only have the kit to R&R that bracket without dropping the pan, it uses (3) 1/4-28 screws to attach after the plate gets tacked inside the pan.
These kits became so popular I can't keep them on the shelf, the last two I had Monday are heading to Alaska tomorrow for a member here.
Just made a 1/2 dozen more yesterday!
Thanks, Gary in N.Y.
P.S. Am already looking for a vendor who may have these in stock, if I come up blank I may figure a way to make a few of them in-house here! Shouldn't be all that difficult?? Here's a couple shots again of the end product!
GOSFAST is offline   Reply With Quote
Old 01-24-2020, 09:39 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I just recently got an email message from Bob Drake saying he was reproducing these oil dipstick tube mounts. The pictures included with the email show the standard version, and the version with a threaded holes for an oil return line. Not sure if the message said they were coming soon, or already available at a cost of about $32.00 each. I think gasket and rivets will be included....but I think I would go with the internal plate with three threaded holes, and SS screws, + lock washer's.
John
Old 01-24-2020, 09:44 AM   #10
Tim Ayers
Fred from Southside Obsolete sells NOS ones for $20.00.
Don't pay more for off shore junk when you can get the real deal for less.
Old 01-24-2020, 12:12 PM   #11
JM 35 Sedan
Very true. NOS is usually the best.
John
Old 01-24-2020, 12:35 PM   #12
35fordtn
35fordtn's Avatar
This is the kit we sell to mount them. I use lock tite in the threads and the appear as Though they were riveted and will never leak. We stock the boss but they are more than the $20 Fred Wilner gets.
Old 01-24-2020, 04:29 PM   #13
51woodie
51woodie's Avatar
Could closed end "POP" rivets be used to fasten the boss to the pan? They are liquid tight, would compress the gasket and come in all sorts of sizes. There would be no need to remove the oil pan if the engine was still in the car.
https://www.hansonrivet.com/rivets/b...-blind-rivets/
51woodie is offline   Reply With Quote
Old 01-24-2020, 04:35 PM   #14
35fordtn
35fordtn's Avatar
I would surely think so.. This parts has no real pressure on it, and I would think a pop rivet would accomplish the same principle. At least then as you say, you would not need to remove the pan to replace assuming one could remove the old rivets without pieces of them falling into the pan.
Old 01-24-2020, 07:14 PM   #15
Jack E/NJ
Jack E/NJ's Avatar
Sheet-metal screws will also work with silicone sealer on the threads next to screw heads. Use pan-, truss- or round-head screws to look like rivets by filling slots with aluminized sealer. Jack E/NJ
Old 09-03-2020, 07:04 AM   #16
Matt1765
Hi,
Before reading this, this was my plan, I am going to put a horseshoe of earth magnets below the boss, grind the external head off, remove the old boss, slide the magnets to the hole removing fragments and use a closed head. My only question now is can I get a pop rivet hun in the area? Will let you know this winter when I try.
Matt1765 is offline   Reply With Quote
Old 09-03-2020, 07:06 AM   #17
Matt1765
Can someone provide me an email or contact as to where I can purchase the boss for a 1949-1953 CM, gaskets please? My email is [email protected].
Old 09-03-2020, 07:51 AM   #18
Tim Ayers
Reach out to Michael D. @ Third Gen. Auto in post #14.
Old 09-03-2020, 10:51 AM   #19
JSeery
JSeery's Avatar
You need to CALL Michael, text, emails, PM, etc mostly will not work.
