As part of pulling my engine to do some work on the AA I decided to see just how much oil is left in the engine after draining the oil.
I drained the oil allowing about 10 minutes of time until I put the plug back in. Then I pulled the engine and mounted it on my engine stand. After getting it on the stand I pulled the drain plug and caught the oil. Put the plug back in, tipped and rotated the engine several times over the next couple of days pulling the plug each time and catching the oil. 17 ounces is what was left in the engine. Your results may vary
Dave / Lincoln Nebraska |
Thanks Dave for your experiment. So you found a tad over 1/2 quart of residual oil in contrast to the popular belief that there is 1 quart of residual oil in the engine.
Things that may affect your experimental finding: >When you took / take the engine apart, are there any holes in the dipper troughs in the oil pan tray? >Leakage of oil from the valve chamber via worn oil pump bushings / shaft, and excessive main and camshaft bearing clearances.
Bob Bidonde |
I usually pull the pan with the engine still in the upright position, just because!
Guten Abend,
yes, what Dave wrote I can confirm. A few months ago I had to remove the engine. Also because of the pockets in the valve chamber and because the soldered-in thread insert for the drain screw has a collar, there was a considerable amount of residual oil. I didn't measure it, but I also guess about 1/2 liter / 16 ounces.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
Thank you Werner. I've been trying to work out what they are talking about 17 ounces? 1/2 a quart? It's a different language especially when the US gallon and US ton are unique to that country.
At times, I have tried to find a conversion table or conversion factor but so far, I haven't found one that specified whether the ounces/quarts are US or imperial. Very confusing!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#6 | |
Blame it on the British. Since Australia is still part of “Empire”, I would think you would have kept the weird British System. Wish the U.S. had gone to the Metric System. They teach it in science classes over here but it hard to visualize because everything else is in pints, quarts, and gallons. David Serrano |
#7 | |
Engine was completely rebuilt 5000 miles ago by Herm Kohnke so I'm pretty sure that excessive wear isn't a factor on this one.
#8 | |
The confusion IMO, comes about because we don't know which gallon or quart or ton is being used when figures are quoted. If everybody used metric, we would all know what is going on. As far as I know, the US is the only place in the world that is not. Like you I think the US would be better off gong metric but it's not up to me. When we changed, as I remember, things went quite smoothly with the possible exception of the more senior people who had difficulty for a while getting used to he new way. Kids these days have no clue about the imperial system.
#10 | |
Oh how simple things would be if we all used metric (just ask NASA!).
I thought the accepted amount was 1/2 a qaurt(32oz/.946 liters) or 16ish ounces near to a half a liter. How did rotating the engine get more oil out of the plug? I was expecting you to have pulled the pan and poured the excess into a measure.
Guten morgen Werner, and to all. The reason we here in the States haven't gone metric is because our leaders are just plain stupid!
#13 | |
Sorry just could not resist.😡 |
#14 | |
Machines that are manufactured for the USA or sold to Europe from there require different manufacturing machines and other tools. This makes these devices very expensive. There have also been serious accidents. A Boeing crashed in the USA because gallons were mistaken for liters when checking fuel. The first Ariane 4 had to be blown up because metric and non-metric values were incorrectly implemented in the flight control system. Another major confusion is that the USA not only uses inches for thread of screws, but also use other flank angles. An English inch screw does not fit on an American nut! But we stray away from the topic. I am not entitled to politicize here.
#15 |
I rotated the entire engine while it was on the engine stand not just the crank shaft.
