Old 11-24-2019, 05:02 PM   #1
JT1930
JT1930's Avatar
Default 1937 Cam Regrinding
Can the stock 37 ford cam be reground close to an isky max1 3/4 cam ? Or what is a good sounding cam for a 21stud motor that will have sharp heads on it. Thanks all.
JT1930 is offline   Reply With Quote
Old 11-24-2019, 05:09 PM   #2
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Default Re: 1937 Cam Regrinding
We like the Isky 77B cam grind.
J and M Machine is offline   Reply With Quote
Old 11-24-2019, 05:17 PM   #3
JT1930
JT1930's Avatar
Can the stock cam be ground to that ?
Old 11-24-2019, 05:41 PM   #4
KiWinUS
KiWinUS's Avatar
I don’t see why not. I have re-ground several of those early cams to my KiWi-L100 specs.
Old 11-24-2019, 06:18 PM   #5
JT1930
JT1930's Avatar
Kiwi do you still grind them. I’m looking for someone to do one.
Old 11-24-2019, 06:45 PM   #6
KiWinUS
KiWinUS's Avatar
Yes sir
Old 11-25-2019, 09:36 AM   #7
Ol' Ron
Ol' Ron's Avatar
just curious, Does the cam you have ,has apressed on timing gear.????? Most any cam Grind can be put on a stock cam. Which brings up the application and cost. When re grinding a stock cam, you will have to use adjustable lifters, or longer valves. Also in a stock engine, longer duration reduces low end torque The 77B is very much like a stock grind$$$$$ for changing the cam you must have a good reason.
Old 11-25-2019, 02:57 PM   #8
JT1930
JT1930's Avatar
Ron I’m going with the 1007B cam. The cam I believe is the press on timing gear. With that cam it will have Sharp heads and dual carb intake. Im on the fence on the adjustable lifters, if i run them I will have to make jam nuts for them or just get longer valves and cut them to what I will need.
Old 11-25-2019, 04:15 PM   #9
Bored&Stroked
Bored&Stroked's Avatar
The 1007B is a really good cam - you'll like it in that engine! I tend to run Chevy valves - as I like the longer length. I then make custom spacers for the guides (depending on the cam, springs and how much spring pressure I want on the seat).
Old 11-25-2019, 07:28 PM   #10
KiWinUS
KiWinUS's Avatar
Curious about your Sharp heads. Are they original? Sharp 21 stud hmmmmm any pics of them or history.
Cheers
TP
Old 11-25-2019, 07:52 PM   #11
JT1930
JT1930's Avatar
Kiwi. Repop from h&h. I believe they are about 8:1 compression ratio.
Old 11-25-2019, 07:56 PM   #12
KiWinUS
KiWinUS's Avatar
Ah okay they look great but Sharp never made 21 stud heads like that. I have a laaaarge Sharp collection.
Cheers
Old 11-25-2019, 08:14 PM   #13
JT1930
JT1930's Avatar
Well if I come across someone wanting to give up Evans or cyclone 21 stud heads instead of letting them sit on their shelf I’ll take those too. Hahah.
Old 11-25-2019, 09:32 PM   #14
Bored&Stroked
Cheers
Yo Kiwi . . . what do you know about the early block letter Sharp heads? I've never researched them -- was wondering when they were made and if they're rare to any degree.
Happy TurkeyDay to Yah!
Old 11-26-2019, 10:46 AM   #15
KiWinUS
KiWinUS's Avatar
JT you’re half way there you have Cyclone heads rebadged with Sharp name.
My super popular KiWi-L100 cam originated from your great state of Rhode Island.
Cheers
Old 11-26-2019, 11:05 AM   #16
KiWinUS
KiWinUS's Avatar
G’day Dale well I have a bunch of paperwork from Wilcap that made Sharp products after Al stopped. I have articles with them in late 40,s magazines but what is interesting is the differences in the several sets of Block Letter heads in particular the temp gauge bosses some straight up some angled. I believe they a somewhat rare. Unfortunately Al passed 6 weeks before I was to meet him. I have struggled to find a whole lot of info on his products or what all he made.
And a Happy Turkey day to yourself.
Cheers
Tony
