About three to five months ago a few of us were helping another member exchange another H&H Engine in his coupe. Well we were exchanging that one for a B engine a guy donated to the cause until things got ironed out. My pal was under the car buttoning up the U-Joint and as he came out he staggered a bit and told me that had happened to him recently working on his hot rod 34. Came out from under it and was dizzy for a few minutes. Not a problem, Right? Well no, now it is a problem because it has happened to me twice today as I came out from under my coupe, I found it took me by surprise and it took me a few minutes to get back feeling normal. I called him and we discussed this bit of getting along in years. He has done nothing about it and I wont either until my next visit with the cardiologist, but it seems odd. He still has the same thing hit every time he goes under a car and it is looking like that may be my lot also. Any of you have similar events, know a sure cure, old wives tale, remedy, I'm into whatever? Hate to think all I can do is work topside from now on.
Might try coming back to vertical slowly. Moderation.
You may be hearing alarms going off that aren't there. Especially with the heat we have been having lately. |
Maybe a sudden rush of blood to the head...happens to me occasionally....joys of getting old .Just take it easy and don't dwell on it !
I've had this on and off for years and unwaxing the ears helped.
I was told I probably have benign vertigo. There is a manover you can use for this while lying on your back and turning the head 45 degree's and holding it there for a while ( it's on utube). |
I have same thing Doc sez the older you get when you get up like that it takes a while longer for the blood to expand your veins so as to get enough blood in the system He sez to sit up slowly and then stand up slowly
Seems like vertigo is becoming more common as I have several friends be diagnosed with it. Hopefully it's nothing serious and just doing as some of the fellows mentioned will take care of it for you. Don't ignore it as your body tells you when something isn't right. I went to the doctor and had a stress test done and was told my chance of having a heart attack was %. He actually gave me a number but I can't remember it, it was a low chance I'd have one. Month later in er on vacation getting a blockage opened and stint placed. |
Happens now and then. Allergies my dr. Told me years ago. Now I have a house cat and it happens a little more often. I thought it was the brand of beer I was drinking.
a sure cure, a diet of food you hate to eat. do you check your blood pressure daily? do you take a blood pressure medication? if your need for the medication has increased or decreased light headedness is a side effect. blood pressure pills and alcohol can also cause this problem. not while drinking but the day after. Consult your doctor to see if your meds are at the right levels. Myself a person in pretty good health. I can make my self feel like I have major problems light headedness, chest pain, joint pain, hip pain just from eating poorly. And I am surprised how good I can feel when I go a while without a meal worth eating,
I dont take any meds. But two different people around me have had to change their pills lately one for following his docs diets for the first time in 30 years and the other started doing daily cardio and had to change then change back after getting lazy on the workouts and blood pressure went back up Last edited by mike657894; 09-06-2019 at 08:10 AM. |
While I'm down there I take a nap, then get up. Seriously, I have always suffered from some degree of vertigo but lately it is worse working under cars. I think it is partly caused by having to wear glasses that don't work wel in the direction I'm looking.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
Alll the others are giving you good advice. I have been down this road several times with strokes, heart attacks. bypass surgery, and now I have a defibrillator and pacemaker. Not overweight and fairly active. Still the vertigo happens. One word of advice and that is to go to your doctor and make sure he is on board with your care. Good luck. By the way, I am 83 this month. and still climb under the model A. Jack
You and me Jack. Maybe 83 is a magic number. Thanks everyone, seems quite common in the 80's. I'll recheck the meds with doctor and rise slowly.
Long story short ... My mother had several falls in 2018...
Then one day she did not feel well so went to Doctor. Nurse found a heart beat of 37, three minutes later. Doctor got 60 beats ... I said didn't the nurse get 37? So Doc looked at chart and checked again and got 30... all within 10 minutes. They put her on vitals monitor at hospital for 12 hours ... heart beats were changing every 2 hours or so then going back to 60. Pace maker was installed and (they reset her points gap- ![]() When I talked to Doctor he said there are portable monitors that can be worn to monitor without hospital visits that can detect such conditions. Last edited by Benson; 09-06-2019 at 09:43 AM. |
#13 |
I also have a problem with vertigo,am 77 and it has been the last couple of years,probably age related.
#14 |
Had the same thing. Dr. said it was allergies affecting my ears took allergy meds
and all was ok. Bob |
#15 |
Just saying - if it was me I would get to the doctor. Father had this issue when in his upper 70s, had low blood pressure. An Uncle started having this - partially blocked carotid arteries (neck). Dad was OK with Meds, Uncle had an ultrasound to confirm - then he had them cleaned out and went on blood thinners.
#16 |
I don't have to climb from under a car to get dizzy. Just sticking the golf tee in the ground and straightening up does it, so, I seldom use a tee anymore.[smiley face]
Mine is from lack of blood pressure due to the treatments, which hasn't corrected itself yet. |
#17 |
I had on several occasions the same thing happen to me laying on my back under the Model A and the 53 Buick. Extreme dizziness but only when I was looking straight up. When I would roll over it would go away after a minute or two.
I found out that it was caused by particles in the inner ear being in the wrong place in the canal. The attached "Foster Maneuver" cured it. https://www.webmd.com/brain/home-remedies-vertigo#2-4 |
#18 |
Better to google "Foster Maneuver" and you will get some good videos.
#19 |
I am not a doctor. I think what the guys say is right but I also think I would move up my visit to the cardiologist (unless it is scheduled for tomorrow).
Charlie Stephens |
#20 |
I also had a few instances of vertigo, usually when lying down or getting up from bed. I found out in my case it was the inner ear problem someone posted earlier...small particles breaking off, affecting your equilibrium. There is an exercise to help stop it....mine went away on its own after about a week. Might be your problem.....
