Old 07-25-2019, 02:36 PM   #1
Shoebox
Shoebox's Avatar
Default Shop led lighting
When I built my house with attached shop 18 years ago, for the tall ceiling I used what was recommended, metal halide I believe. Recently several have died, and I never did like the buzzing sound. Now I'm ready to replace all and what I'm hearing is that I should be looking at High Bay LED lights. Just wondering if any of you guys have gone with this sort of lighting. Any recommendations or comments most welcome.
THANKS!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 07-25-2019, 03:01 PM   #2
Newc
Newc's Avatar
Default Re: Shop led lighting
Hi; Retired electrician here... The new Leds are fantastic, I installed High bay t-5s [flor] and did not like the heat they produced. T-8s [Flor] with electronic ballasts can be converted to Led T-8s by just replacement. Note the 'brightness' ratings in Lumuns. Your eyes maybe sensitive. Newc
Old 07-25-2019, 03:03 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Yep, took out all the florescents and replaced with LED.
All purchased on line (EBAY)
Daylight color.
The ceiling is 10 foot and they look great.
The 8 ft fixtures I removed weighed about 15 pounds each.
Old 07-25-2019, 03:40 PM   #4
tubman
tubman's Avatar
Whenever I lose a fluorescent tube, I convert that fixture to led's. I'm about half converted now. I think they're great.
Old 07-25-2019, 04:26 PM   #5
Shoebox
Shoebox's Avatar
Thanks for the responses guys. 51 MERC any info on the units you used, such as watts, lummens ? I'm interested in round lights that can hang from existing hooks.
Scott
32 Ford roadster
39 Mercury Towncar
Old 07-25-2019, 04:32 PM   #6
51504bat
51504bat's Avatar
I replaced all the fluorescent fixtures in my shop with LED fixtures I bought at Costco. The complete units were cheaper than converting the fluorescent ones to LED.
Old 07-25-2019, 04:34 PM   #7
40cpe
40cpe's Avatar
Be aware that some of the bargain priced LEDs are low on lumens output. I think my present t-8 bulbs are about 2300 L per bulb. I have bought some single single bulb LED fixtures for over the workbenches that are rated at 5000 L .
Old 07-25-2019, 05:55 PM   #8
Greg58
Greg58's Avatar
I work for the local school system, we have been converting high bay light in gyms to LED, in one we used a conversation that uses the fixture and wires around the ballast. The light is intense as stated, we used Creed in one and Lithonia in a couple more, the light output is great. If you choose the right lumen you will be amazed.
Greg
Greg58 is offline   Reply With Quote
Old 07-25-2019, 06:19 PM   #9
JSeery
JSeery's Avatar
Like 5150 I replaced the whole fixtures. The LEDs are bright!
Old 07-25-2019, 06:46 PM   #10
glennpm
glennpm's Avatar
I replaced my 8' fluorescents with LEDs about four years ago and they are fantastic! Especially good for instant startup in my cold Maine garage. When I expanded my garage last year I bought more lights from the same company, made in USA and excellent quality.
https://www.hyperikon.com/led/
I used this site's tool to determine lighting requirements:
http://www.visual-3d.com/tools/interior/default.aspx
Old 07-25-2019, 07:27 PM   #11
34pickup
34pickup's Avatar
I also replaced all of my florescent lights with LEDs. What a difference! Instant on, even in cold weather, no noise, twice as bright as before...I can see in the garage now. And they are cheaper to operate, plus last much longer so I am told.
So, whats not to love? Switch over. I wonder why I waited so long.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-25-2019, 10:14 PM   #12
4tcoupe
Smile Re: Shop led lighting
I replaced my old shop lights with the clear leds last fall, had mixed results. Had to buy darker sunglasses , found tools and parts I thought I lost 25 years ago .
Love them. JT
4tcoupe is offline   Reply With Quote
Old 07-25-2019, 10:20 PM   #13
Tinker
Tinker's Avatar
There are basically two color temps also for most LEDS. Warm (amber) and blue. Blue are very bright and can seem odd in a house, much brighter. I like warm colors for the home and blue/clear light for shop, etc.
I replaced 2 florescent hanging units with 6 100w leds bulbs and the old regular (cheap) incandescent ceramic fixtures (rewire). Doubled my light in the house garage.
Old 07-26-2019, 12:15 AM   #14
flatheadmurre
flatheadmurre's Avatar
I replaced all the fluorescent tubes with leds a few years back and i got to choose between Warm-Daylight-Cold for color. Went with daylight since even though the cold seemed much more bright it was kind of sterile.Was told Warm is for living areas and Cold for industrial.
Very happy with the Daylight choice that is in middle.
Old 07-26-2019, 01:00 AM   #15
Tinker
Tinker's Avatar
Sterile is a very accurate description of blue/cold leds.
Old 07-26-2019, 03:02 AM   #16
jrvariel48
jrvariel48's Avatar
You can save yourself some money by just replacing the lamp. You will have to wire the socket directly with 120/240 voltage you have at the fixture. You leave all the wiring for the ballast, starter, etc. out.
jrvariel48 is offline   Reply With Quote
Old 07-26-2019, 03:28 AM   #17
Tinker
Tinker's Avatar
240 for shop lights? thats like street light voltage
Old 07-26-2019, 05:52 AM   #18
flatheadmurre
If you have old magnetic ballasts you can leave them in...the electronic ones has to go.
The led tubes come in 2 types...one has both connections at one end usually the newer dimmable ones are this type...the other type has one connection at each end.
Old 07-26-2019, 06:36 AM   #19
glennpm
glennpm's Avatar
Leaving the ballasts in the circuit increases the power required for the LEDs, also another source of failure with the ballasts. I went with the ballast bypass type, a little more wiring but worth it to me.
Old 07-26-2019, 06:58 AM   #20
TagMan
I tossed all the 4' flourescents in my 30'x40'x12' shop with LEDs from Sams club about 2-years ago. 8 units light it up like daylight immediately even in the coldest weather. I love them and will use them in the new shop I'm building.
TagMan is offline   Reply With Quote
