Old 07-22-2019, 08:55 AM   #1
DannL
DannL's Avatar
Default Jacking up car . . .
Are there any specific "preferred points" to place the car jack when lifting the Model A? So far I have lifted only under the middle front axle and under the middle differential. In both cases I was lifting two wheels off the ground. If I wanted to lift just one wheel off the ground at a time? Don't want to bend anything that's not already bent. ;-) Thanks in advance. Dann in OKC
DannL is offline   Reply With Quote
Old 07-22-2019, 09:23 AM   #2
daveymc29
daveymc29's Avatar
Default Re: Jacking up car . . .
I have just jacked one end of the front or rear axles to lift just one wheel. Have not raised them more than an inch or two. Have not found that to be bothersome, I hesitate to say about raising by a mid-frame jacking. I fear that may cause more problems than it will cure unless one used two jacks simultaneously. It would seem to be okay for a short period of time, but to leave it a week or so up on one jack would be inviting trouble, I believe. But what do I know? These frames may be stronger that I think. Your results may vary.
daveymc29 is offline   Reply With Quote
Old 07-22-2019, 11:12 AM   #3
WHN
This would be my opinion also. I think the rear end would especially be a place I would not want to jack up from its center.
We have always jacked up one corner at a time. Putting car on jack stands.
Old 07-22-2019, 03:33 PM   #4
1931 flamingo
1931 flamingo's Avatar
The A's and all early Fords have been jacked up under the center of the diff since Cxxxxt left Philly. with no problems..................JMO
Paul in CT
Old 07-22-2019, 04:30 PM   #5
100IH
I agree with Paul. Front or rear by center or end, but then place a jack stand and remove jack. Easiest is lift in center and stands to the outside.
100IH is offline   Reply With Quote
Old 05-08-2020, 01:36 PM   #6
DNLs1930
DNLs1930's Avatar
OK so jack goes under differential or front spring and both wheels come off the ground; got it.
Question is where should I put the jackstands? I would think on the the axle housing more outboard towards the wheels onthe rear but where on the front? IS the frame near the wheels used as the jackstand contact position?
I have never jacked or supported a Model A so please take it easy on me
Pictures are welcome...
As always THANK YOU for all the help!!
DNLs1930 is offline   Reply With Quote
Old 05-08-2020, 04:44 PM   #7
Bruce of MN
Bruce of MN's Avatar
I put them under the axles for most work. Axle work would require the jackstands under the frame.
Old 05-08-2020, 04:54 PM   #8
Sunnybrook Farm
Sunnybrook Farm's Avatar
Stay away from the running boards!
Sunnybrook Farm is offline   Reply With Quote
Old 05-08-2020, 05:09 PM   #9
Tacoma Bob
Tacoma Bob's Avatar
I place my jack stands just inboard of the spring perches.
Tacoma Bob is offline   Reply With Quote
