My friend just bought a frame with stamped numbers A0467968?
Can u tell what it was originally ? Thank you gump |
The "0" is not correct??? what gives with that and are the stars there also,
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
Try this number. A6467968 then star. Thank you
![]() Too large of a number
Frame # matched engine...
Engine #0467968 was made on Sep 27, 1928 http://www.modelahouse.com/cgi-bin/enumbers/numdate Last edited by IrishHills; 03-16-2011 at 04:03 PM. |
If the number is A467968 it would relate to an engine built on September 27th of 1928. It would have been one of 4392 engines built that day. The frames were stamped with the engine number at the time of assembly. |
Ok thanks
Is the frame only stamped in one area ? Or multiple? Like 1940? |
There would have been NO "0" in the number at all
ok thanks Bob--- don't know much about A's......but here's a new number -----star A3467968 star------
just trying to help my old friend out!!!! thank you GUMPY |
Engine #3467968 was made on May 23, 1930
ok thanks joop
#13 |
This is what our 1930 Phaeton's frame serial number looks like. The car came out of the Mohave desert so there wan't any rust hinding the frame number.
#14 | |
![]() Quote:
#15 |
So if my frame is stamped *2909353* that means that the engine had that serial Number? I am trying to find out what the body style was for the original vehicle. I believe the frame is 1928/29, but do not know if coupe, phaeton, truck or ???? I am new at this, so any help is appreciated.
#16 | |
![]() Quote:
#17 |
If you have two extra body mount holes where the rear of a pickup cab ends, and the holes look original, bit hard to discern if they were done on the assembly line after 85 years , but if you could, this would mean it was a pickup.
And vice versa, if there are no holes there, it means it definitely was not a pickup (from new ). Last edited by pooch; 09-28-2014 at 09:18 PM. |
#18 |
Can you provide as much information as you can about frame number "AX2911751". I believe it was stamped in February 1930. Is that correct? What does the "AX" indicate? Thank you, Warren
[email protected] |
#19 |
#20 |
Hi, could you post a picture of the serial number from a little farther back so I can see exactly where I'm going to have to look for my A's serial number? Also, is it possible to see the number with the apron removed and the body lifted a couple of inches? Thanks.
