Old 05-27-2019, 06:28 PM   #1
48superd
Default 1946-48 trunk inner panels
I'm installing new side inner trunk panels in a 1948 2 door sedan. Does anyone have pictures of how they attach? My original panels were missing. Thanks
48superd is offline   Reply With Quote
Old 05-27-2019, 07:11 PM   #2
Wat-0
Wat-0's Avatar
Default Re: 1946-48 trunk inner panels
Oval headed sheet metal screws with cup style finishing washers.
Wat-0 is offline   Reply With Quote
Old 05-27-2019, 08:52 PM   #3
FortyNiner
FortyNiner's Avatar
No pics here but just dry fit them. The fastener locations will be apparent.
Old 05-28-2019, 12:55 PM   #4
48superd
Looks like I might have to trim the bottom of the left to clear to gas filler....is that correct?
Old 05-28-2019, 02:59 PM   #5
supereal
supereal's Avatar
Some, such as the panels in my '47, are secured by two legged clips with a round button top, similar to the kind sometimes used on door panel trim. I don't recall having to alter the panels for the gas tank filler, but my car is a convertible, so much of the trim, etc, is considerably different from closed cars because Ford farmed out the bodies of the open cars. A good example is the window regulators, which require 9 turns to raise or lower the glass.
supereal is offline   Reply With Quote
Old 05-28-2019, 03:38 PM   #6
51woodie
51woodie's Avatar
My '46 Coupe is like Wat-0 says, screws with cups.
51woodie is offline   Reply With Quote
Old 05-28-2019, 03:40 PM   #7
TJ
TJ's Avatar
Make yourself a cardboard pattern first and trim it to fit. Then transfer it to the new panel.
Old 05-28-2019, 07:38 PM   #8
Kube
Kube's Avatar
Slotted screws on a 46? Stainless?
Old 05-28-2019, 08:15 PM   #9
51woodie
51woodie's Avatar
Kube. There was lots of things done on this car by the po’s, and I have been picking away at correcting/fixing things. Thanks for catching the screws.
Old 05-29-2019, 11:28 AM   #10
Kube
Kube's Avatar
I wasn't criticizing by any stretch. Rather, I was inquiring.
I've only restored two postwar Fords.
I do know the finish is supposed to be S15, oxidized - not stainless.
Old 05-29-2019, 01:16 PM   #11
51woodie
51woodie's Avatar
Kube. I didn't take you comment as criticism. From and education point of view, I think I'm in about grade three in my knowledge of old Fords. The posts of yours that I have read, puts you in the Professor category. I still have a lot to learn. I looked up "Luggage Compartment" in my 1941-48 EFV8 book after your post, and there it was, on page 3-25. The composite liners are held in place with small black finish screws and a washers, and with black painted push type retainers. I think I just graduated to grade four!
Old 06-03-2019, 07:54 PM   #12
edhd58
edhd58's Avatar
EVERY screw I have removed on mine so far has been slotted. The kits to replace them have Phillips, which I dont like.
edhd58 is offline   Reply With Quote
