Old 01-30-2019, 02:54 PM   #1
Werner
Werner's Avatar
Default Oil classification
Hello everybody,
can someone please tell me the API or SAE classification for an oil that is labeled "30 - 40 Weight" in the USA?
Thank you in advance.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-30-2019, 03:32 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Oil classification
30 weight or 40 weight oil has VISCOSITY of SAE 30 or SAE 40. It says nothing about the API classification.
To understand this, you really need to read for yourself.
API: http://www.pqiamerica.com/apiserviceclass.htm
SAE oil viscosity: https://www.jcmotors.com/images/unde..._viscosity.pdf
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 01-30-2019, 04:14 PM   #3
Werner
Werner's Avatar
Hello Jim,
thank you for yout helpin' answer. That was what I want to know, the viscosity.
Werner
Citroen 11 CV, 1947
Old 01-31-2019, 04:54 AM   #4
Werner
Werner's Avatar
I did not understand the word "weight" correctly. Weight means for me a weight, z. kg or lb etc.
If I understand correctly, is here in this case the vocabulary "Weight" equal to the viscosity?
Example "Weight 10" = SAE 10. "Weight 50" = SAE 50.
Werner
Citroen 11 CV, 1947
Old 01-31-2019, 09:29 AM   #5
Terry, NJ
Terry, NJ's Avatar
The oil industry uses the words "Light" and "Heavy" to describe viscosity, Saudi Light or West Texas heavy to describe crude oils. Each crude is different as it comes out of the ground. This is used through out the industry. Light oils are thinner and pour easier. Heavy oils are thicker and can not be poured as easily
I hope this helps.
Terry
Old 01-31-2019, 10:19 AM   #6
BillEbob
BillEbob's Avatar
I hope this helps.
Terry
I may be wrong, but I don’t think his question is about “crude” oil, but rather he’s concerned with the viscosity of oil he may put in his crankcase.
BillEbob is offline   Reply With Quote
Old 01-31-2019, 10:27 AM   #7
1930artdeco
1930artdeco's Avatar
Yes you are correct in you understanding.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-31-2019, 11:25 AM   #8
Terry, NJ
Terry, NJ's Avatar
Yes, but I was trying to show the origins of the designations "light and heavy" The crude oils were called by these terms and the designations carried over into the refined products too. The light oils pour easily and the heavy oils don't, whether as crude or refined. Sorry I didn't make that clear. In Germany, they use DM (?) specs on everything. It's like our ASE or API but I don't how they grade oils, so I don't know exactly what numbers he's dealing with. Their 30 wt may be equivalent to our 90 wt or it may be the same. I don't know!
Terry
Old 01-31-2019, 03:30 PM   #9
Werner
Werner's Avatar
Many thanks for all these helpfull answers!
My question arose because the Stipe shock absorbers instructions wrote "Use Oil Weight 30 or 40".
I know a lot about lubrication, because that was my job. But the US name "weight" instead of "SAE" was previously unknown to me.
Here car oils are always marked according to SAE and API. SAE 10 - 60 for car engine oils. From SAE 70 - 140 gear oils. Then there are also multigrade oils. 5W-40 is the universal oil. But there are also very thin 0W-30 oils or very long-splayed 10W-60.
An infinite material to discuss! I drive in all vehicles only synthetic esters, which burn almost without residue.
Werner
Citroen 11 CV, 1947
Old 01-31-2019, 03:31 PM   #10
Jim/GA
Jim/GA's Avatar
Yes, Werner, you are correct. This is odd, old, terminology. English can be very unpredictable.
Jim Cannon
Old 01-31-2019, 09:53 PM   #11
40 Deluxe
Werner, The word "Weight" is incorrect! The 'W' used in "20W" or "30W" means "Winter", NOT "Weight"!
Years ago oil viscosity was just 10, 20, 30, 40, 50. As refining methods improved 10W, 20W, 30W, etc. became available. A 'W' (or Winter) oil has a lower pour point. So a 20 and a 20W oil have the same viscosity when hot (typically 212 F. or 100 C.) but, the 20W oil is 'thinner' (flows better) at low temperatures.
Here's a quote from "machinerylubrication.com": "the 'W' designation..is used to denote oils that are suitable for use at colder temperatures". And, "The winter (W) group measures the cold-cranking and pumping ability of oil temperatures as low as minus 10C. to minus 40C.".
This is just a brief comment. A lot more detailed explanations are on that website.
Just remember, it's Winter, not Weight!
Old 02-01-2019, 07:54 AM   #12
Patrick L.
Patrick L.'s Avatar
When it comes to multi-weight oils, 10W40, This oil has the viscosity of a 10 weight and the film strength of a 40 weight.
Old 02-01-2019, 08:15 AM   #13
Werner
Werner's Avatar
Hello Patrick,
that is misleading. SAE 10W-40 means that the oil when cold flows like a SAE 10W (winter) single-grade oil and -40 means that it flows in the hot engine like a thick (summer) SAE 40 single-grade oil.
Werner
Citroen 11 CV, 1947
Old 02-01-2019, 10:50 AM   #14
40 Deluxe
The correct term is "multi-viscosity" oil, not "multi-weight". n The 'W' stands for "Winter", not 'weight'.
