Old 10-14-2018, 01:15 PM   #1
Fugal 41
Default Fan Clutch
1941 Ford Tudor Flathead V8, Fan mounted on crankshaft. Has anybody installed a modern fan clutch? Thanks, Larry
Fugal 41 is offline   Reply With Quote
Old 10-14-2018, 03:16 PM   #2
drolston
drolston's Avatar
Default Re: Fan Clutch
Whatever you come up with needs to have at least as much fan blade area and pitch as the stock fan, because the crank mounted fan does not get the "overdrive" speed of a separately mounted fan with a pulley smaller than the crank pulley.
Reminder to all crank mounted fan owners, be very careful if you turn the engine over by pulling on the fan blades; they bend easier than you might think.
Old 10-14-2018, 04:50 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The purpose of a fan clutch is to save engine power which I doubt you would even notice
You may be better off adapting a flex-blade fan with more blades that pump a lot of air at low engine speed and less at high RPM's.
Old 10-14-2018, 06:47 PM   #4
Fugal 41
Thanks for the comments. Think I just stay original.
