Old 10-03-2018, 04:14 PM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default F-1 steering wheel
I assume mine is the original that came with the truck...... here's the issue-
humid or rainy outside and my steering wheel is gooey. I'm sure there was some kind of coating on it originally but not anymore. I've got cracks as well
in it, but I digress.
Looking at some wheels out in cyberland and I see some that don't have the two tapped holes (to use a steering wheel puller) and I assume those wheels may be for F-7 and bigger. The ones with the tapped holes appear to be F-1 to F-6. (supposedly the wheels aren't the same)
My F-1 wheel doesn't have any tapped holes though......
Did Ford make a change to the wheels at the service level and put the
two tapped holes into play?
1948F-1Pickup is offline   Reply With Quote
Old 10-03-2018, 04:21 PM   #2
adileo
adileo's Avatar
Default Re: F-1 steering wheel
Not sure this helps but my 52 F1 has the two puller holes
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-03-2018, 04:30 PM   #3
alanwoodieman
they were originally a hard soybean plastic which tended to shrink as it aged and then the cracks appeared. I wonder what caused yours to get gooey, never seen one do that before. My 49 8n Ford tractor has the same soybean plastic and this year if it gets wet it comes off all over your hands but still is not gooey. allways something new with these old Fords!
Old 10-03-2018, 06:58 PM   #4
FortyNiner
FortyNiner's Avatar
It is possible to repaint the wheels and seal with a quality clear coat.
Old 10-03-2018, 07:33 PM   #5
alanwoodieman
yes, I have restored a number of steering wheels, one on my 40 was done in 1990 and still looks good
Old 10-03-2018, 08:21 PM   #6
Ken Crans
Ken Crans's Avatar
Cant think of the name of the 2 part epoxy to fix the cracks??/ A good epoxy etching primer and some lacquer paint if you can find should do the trick, Did mine about 5 years ago still looks new with no rash on your hands
or the gooey feeling from the bakelite. Good luck!
Ken Crans is offline   Reply With Quote
Old 10-03-2018, 09:19 PM   #7
FortyNiner
FortyNiner's Avatar
Either the POR brand putty filler or the JB Weld Plastic putty work.
Old 10-04-2018, 07:13 AM   #8
chap52
chap52's Avatar
Did my F-1 steering wheel a few months ago. Had a few cracks which I touched up with the Dremel tool. Used PC-7 Epoxy (Amazon Prime) to fill the cracks/dents. Hardens and can be sanded/shaped as needed. Wiped it all down with Grease/Wax remover (paint prep, TCP Global) and painted with Rustoleum Gloss Black Engine Paint. Looks great and no dirty hands.
www.pcepoxy.com
Old 10-04-2018, 08:57 AM   #9
Firepower flyer
Firepower flyer's Avatar
My 50 F1 from orginally form Texas has a very dry steering wheel that would leave your hands black but dry not gooey. I wiped it down with brake cleaner and spray painted it black while still on the truck,it's been fine ever since.
Firepower flyer is offline   Reply With Quote
Old 10-04-2018, 12:59 PM   #10
rotorwrench
rotorwrench's Avatar
All the F1s, the F3, and the F6 we had back on the farm, had the hard rubber steering wheels. They left your hands black if they set for too long between use. The black would stop rubbing off after a day or so of use. We used them hard all summer then they would set during the winter except for the F3 we used as a water truck to fill the stock tanks. Ford likely used both Bakelite and hard rubber (Ebonite) in the flathead era.
Old 10-04-2018, 06:00 PM   #11
glennsanders
glennsanders's Avatar
I have pulled many steering wheels of the f series trucks some with and some with out . Don't know why some have and some don't.The ones with out drill and tap 2 holes and pull it.
glennsanders is offline   Reply With Quote
Old 10-05-2018, 11:03 PM   #12
1948F-1Pickup
Interesting. Maybe I'll drill/tap and pull this one...... and then
repair it and find something to coat it.
Old 10-05-2018, 11:34 PM   #13
Tinker
Tinker's Avatar
That's interesting. I knew 42 dashes were soy bio-plastic. Wasn't sure the extent of its usage.
Would be interesting to know the usage among the years.
Old 10-06-2018, 10:14 AM   #14
rotorwrench
The soy fiber was used in the phenol formaldehyde resin. For the most part, the plastic Ford made using soy material was a form of bakelite. The car they made as a prototype in 1941 was that way. Soy bean flour can be cross linked with chemicals to create a soy based adhesive but I don't know how strong or resilient it would be. There is still ongoing research in soy bean based plastics.
Old 10-06-2018, 08:41 PM   #15
Dick Webber
I filled a few cracks with epoxy then painted with PPG single stage Concept urethane. It has held up well for more than 15 years
File Type: jpg B6537E84-9142-4425-9323-D7284E1F189F.jpg (64.0 KB, 20 views)
Dick Webber is offline   Reply With Quote
Old 10-07-2018, 07:53 PM   #16
Clem Clement
Clem Clement's Avatar
My wheel came from a junk Yard. It lay out in the wx and most of the goo has been baked out. This morning in the gooey wx, it was sticky but did not give off the black stuff.
Old 10-10-2018, 02:51 PM   #17
GreenMonster48
GreenMonster48's Avatar
Drill and tap it!!!!
I replaced my stock wheel with a '49 passenger wheel a few months ago. I had no holes and it was an absolute nightmare. I should have tapped it right off the bat.
Not having black crap or goo on your hands from the old wheel is well worth it
GreenMonster48 is offline   Reply With Quote
Old 10-11-2018, 02:12 AM   #18
big job
big job's Avatar
I use a bearing separator under the wheel & the puller now a days lots of stores rent
things like that. I tend to think it was the early F series didn't have tapped holes. I have
the same nasty problem with my car damp humid rainy I have to wear gloves. Its sticky
black like soot. I keep looking for a new one no luck yet. 46 to 1948 wheel. At least
they make new wheels for F1 to F6. F7 & F8 no one makes those.
big job is offline   Reply With Quote
