Old 09-14-2018, 11:44 AM   #21
Karl Wescott
Karl Wescott's Avatar
Default Re: California Gas problem
Originally Posted by BILL WILLIAMSON View Post
Seems that crap gas problems are more common in HIGH HUMIDITY areas. Along with points oxidizing!!
Bill Dryplace
Not surprising. Water is soluble in alcohol (and visa versa). So when e-gas is exposed to humidity in the air it will absorb water, if it becomes saturated and then cools the water will precipitate, often forming a gel like emulsion (scum) with the oils in the fuel.
Before e-gas you could buy a little bottle of methanol to dump into your tank to pick up any water at the bottom of the tank, parts stores sold it under various names.
Karl Wescott is offline   Reply With Quote
Old 09-14-2018, 11:49 AM   #22
30 Closed Cab PU
Is California Gas formulated different than the rest of the U.S.?
Old 09-14-2018, 11:55 AM   #23
Jeff/Illinois
Jeff/Illinois's Avatar
I have NO GAS PROBLEMS, SOLD all my cars!
Bill Walkin'
But, do YOU still get 'gummy and clogged up??
Old 09-14-2018, 11:56 AM   #24
Jeff/Illinois
Originally Posted by Y-Blockhead View Post
MTBE was found to be poluting the ground water. That's why they stopped using it. Otherwise we would still have that in our gas also.
MTBE was used in other states besides California. New York was another big user.
And that stuff was a real cancer causer pretty carcinogenic.
Old 09-14-2018, 01:46 PM   #25
Dan Partain
Dan Partain's Avatar
I've never had a problem with water in my fuel until the last couple of years. I suspect it's either the cheap local gas station I've been buying gas from, or the tendancy of ethanol to pick up more water, or a combination of both. In any case it's causing a problem with my fuel filter and the float valve in my carb. I have the pencil filter in the tank, the iron fuel filter, and the filter in my carb all in good shape.
I was buying a new leaf blower yesterday and the subject of fuel, E10, and water came up. My friend who owns the saw shop told me of a product that he has used to help clear out water from fuel. He did some experimenting with the product and had a couple of small jars with old fuel and water that he did a test with.
The product is K100. I bought a small bottle and I'm going to run it through my Tudor fuel tank and then start buying my fuel at a better gas station from now on to see if that helps.
When I got home I searched the internet to see if I could find out more about K100 and found this video which was very similar to the test my friend had made.
https://www.youtube.com/watch?v=NegB8gRPMlU
Has anyone else had any experience with this product?
Dan Partain is offline   Reply With Quote
Old 09-14-2018, 02:12 PM   #26
30 Closed Cab PU
Here is some info, I raised the same question recently. You can read and decide for your self. Especially interesting is the info from fuel-testers.
Please post your results/experience with the K100.
https://www.fordbarn.com/forum/showthread.php?t=250776
http://www.fuel-testers.com/review_g..._products.html
https://www.fordbarn.com/forum/showthread.php?t=121018
https://www.fordbarn.com/forum/showthread.php?t=250757
Old 09-14-2018, 03:41 PM   #27
WHN
Model A’s will run on almost anything. Use MMO, I think it works great.
Old 09-14-2018, 03:43 PM   #28
corvette8n
corvette8n's Avatar
Jay Leno says you can't event light it with a match.
Old 09-14-2018, 05:30 PM   #29
daren007
Sometimes my wife says I have a gas problem.
daren007 is offline   Reply With Quote
Old 09-14-2018, 11:12 PM   #30
31 Woody
31 Woody's Avatar
They make a big deal out of which formula of gas we are getting here. ‘Oh the Summer gas formula is rolling out, so prices are up $0.20/gallon.’ Then in the Fall we hear ‘Winter formula supply struggles have surged gas prices another $0.22 /gallon.’ Then of course there are the hurricanes, floods, wars, and other factors. Is the gas different? Well, the price sure is! Economics at work.
I keep waiting for the announcement that bootleg ‘49 State’ gas is $2.79 available Statewide. I will keep breathing in the meantime.
Experience is a cruel teacher. It gives the exam first, then the lesson.
The first 4 hours of a 30 minute repair job are the worst. The next 2 hours usually go much better.
31 Woody is offline   Reply With Quote
Old 09-16-2018, 12:10 AM   #31
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
NO! Like they say, "WHEN YOU'RE OLD & PEE & POOP GOOD, YOU'RE DOING OK"
Bill Pooper
"THE ASSISTANT GURU OF STUFF"
Old 09-16-2018, 02:34 PM   #32
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by 31Abone View Post
My neighbor's 28 just crapped out last week it was sticking float valve,I had two model A's that had the sticking float problem ,I put carb cleaner in and seemed to help ...tanks have no old sealer in them or rubber hoses..I think when an A sets for a week or two the fuel drys out in carb and makes needle valve stick kind of gummy type crap in the fuel....thats my opinion anyway.
I agree, and the corn crap can also make valves stick due to the sticky residue it leaves. MMO helps, and I always use it.
Old 09-16-2018, 06:27 PM   #33
Jeff/Illinois
I use MMO here also. Had a sticking valve issue in the Flathead and that brought it right out of it.
They tell me today's gasoline is too 'dry' and you need a little lubricant for the old motors to make them work right.
