Old 08-13-2018, 08:37 AM   #1
davidGR
Default What horn size?
Hey guys my Model A didn’t come with a horn
I’m looking at a 13in Sparton rebuild on eBay, but is that to long?
Your guys thoughts, anyone have pictures of a 13in sparton on your A?
Thanks
David
davidGR is offline   Reply With Quote
Old 08-13-2018, 08:44 AM   #2
jw hash
jw hash's Avatar
Default Re: What horn size?
just put down the Ebay item number. and someone here will tell you if is correct or not.
jw hash is online now   Reply With Quote
Old 08-13-2018, 09:12 AM   #3
davidGR
https://www.ebay.com/itm/9-Original-...d884%7Ciid%3A1
Old 08-13-2018, 09:15 AM   #4
John
John's Avatar
Not a correct Model A horn.
John is offline   Reply With Quote
Old 08-13-2018, 09:21 AM   #5
rocket1
Brattons sells a repro horn for $275. to $285. they can still be found in the flea markets for less but might need work.
rocket1 is offline   Reply With Quote
Old 08-13-2018, 11:05 AM   #6
Big hammer
Ebay is jumpy for me, but the motor looks ok and the motor cover. You could replace the bell with repop one or a used one!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 08-13-2018, 12:45 PM   #7
frank55a
What I have seen good "A" horns will generally run around $150 to $200 at most swap meets. There have been some advertised here on the swap meet page. The cover, bell and wire connections are not correct on the e-bay horn. By the time you would purchase that horn, buy the correct parts and pay for shipping, not to mention the work, I think you would have more $$s into it than it would cost to buy an original correct horn.
frank55a is offline   Reply With Quote
Old 08-13-2018, 03:18 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
But if you keep looking you can find one cheaper, or in pieces, I bought enough to make a horn at Hershey for less than30$
Old 08-13-2018, 03:35 PM   #9
1955cj5
1955cj5's Avatar
Thanks
David
The original rebuilt Sparton that I have is about 9 7/8" long, end to end.
I had one of the longer style horns before. Similar to the one you referenced but was a North East Electric brand. It worked fine but used a eyelet type connector instead of the bullet type that the original uses, so you would have to make an adapter or modify your wiring harness.
You would also need a mounting bracket for the Model A, here is an example:
https://www.brattons.com/28-30-horn-bracket.html
This is a picture of the longer North East horn mounted on my '29 pickup.
If you just need a horn there is no reason why that ebay horn wouldn't work for you if it functions correctly, even though it's not an original style..It took me a couple of years to find the correct horn for my ccpu.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-13-2018, 08:21 PM   #10
rogerkb1936
rogerkb1936's Avatar
mine is a little less that 10". horn that is
rogerkb1936 is offline   Reply With Quote
Old 08-14-2018, 09:02 AM   #11
SSsssteamer
SSsssteamer's Avatar
The eBay is all wrong for the Model A Ford. Not mentioned yet is that the electrical terminal studs on the eBay horn are on the outside of the horn, where as the bullet connector terminals on the model A horn are located on the inside the back horn cover. Yes, the eBay horn is longer too, and most likely, the pattern for the screws that hold the horn bracket are too far apart for the model A bracket too.
SSsssteamer is offline   Reply With Quote
Old 08-14-2018, 11:52 AM   #12
ryanheacox
ryanheacox's Avatar
https://www.ebay.com/itm/ALL-ORIGINA...el+a+horn.TRS0
Thats the what you should be looking for if you want the correct style horn for your car. Not sure if the one in the link is a good price or not, for $100 more than that you can get a brand new one from brattons with the bracket already attached.
Old 08-14-2018, 02:39 PM   #13
Sparky
Sparky's Avatar
It's not guaranteed that a Model A bell will fit. When I rebuilt my Sparton model AU horn (the Model A version is a Sparton AF) I ordered new bell gaskets thinking they were the same size. I found out that the flange on the AU is slightly larger diameter than the AF, so the gasket did not fit (and a Model A style bell wouldn't have fit either.)
Here is a link to my horn:
https://www.fordbarn.com/forum/showthread.php?t=247851
Sparky is offline   Reply With Quote
Old 08-16-2018, 09:02 AM   #14
JohnLaVoy
JohnLaVoy's Avatar
The reproduction horns are made by A&L and are excellent. They are correct in all details and the motors are superior to the original. You would be happy with one of those.
JohnLaVoy is offline   Reply With Quote
