Old 04-08-2018, 06:24 PM   #1
Great Lakes Greg
Great Lakes Greg's Avatar
Default unusual head torque issue
Not really an issue, just curious. I have a fresh rebuild with a 5.5 head initially torqued to 60 lbs. Ran it once and got some good heat through it, cooled off completely and went to re torque the nuts. Unlike a dozen times before on various engines, the nuts held they're torque. I pulled up to 75 pounds thinking they would "TINK" and then turn at a lower value, but they didn't budge, so I let off. I'm fine with it, I guess, just never experienced this before. Thoughts from the experts?
Great Lakes Greg is offline   Reply With Quote
Old 04-08-2018, 06:39 PM   #2
Wick
Wick's Avatar
Default Re: unusual head torque issue
Don't worry about it. Run it 50 miles and check them again.
Wick is offline   Reply With Quote
Old 04-08-2018, 06:44 PM   #3
Step-down
Step-down's Avatar
Im at the same stage but on a 59 V8 . I've had motors hold but this time after first heat cycle I felt some of the bolts move. That right I used 8ba bolts on a 59 ,no studs . First try ...
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 04-08-2018, 08:00 PM   #4
J Franklin
J Franklin's Avatar
So I'm confused. What is your final torque?
J Franklin is online now   Reply With Quote
Old 04-08-2018, 09:47 PM   #5
40 Deluxe
It's called "stiction", that initial resistance to turning. Always back off the nut about a quarter turn or so first, then torque to specs.
Old 04-08-2018, 10:05 PM   #6
iverson
iverson's Avatar
40 Deluxe you may be right but I dont think I would back em off. if everything is staying tight thats good leave it alone thats my opinion
iverson is offline   Reply With Quote
Old 04-08-2018, 10:15 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What head gasket did you use?
Old 04-09-2018, 05:12 AM   #8
James Rogers
James Rogers's Avatar
Did you install the head gasket? I will post a guess after you answer this.
James Rogers is offline   Reply With Quote
Old 04-09-2018, 05:45 AM   #9
old31
One, I always thought never to back off the nut.
Two, 75 lbs is too much. It should be 55 lbs.
old31 is offline   Reply With Quote
Old 04-09-2018, 06:09 AM   #10
Great Lakes Greg
It is a Rich Fallucca engine. I don't know what kind of head gasket he used. I am inclined to leave it alone as some have suggested. I did not tighten them to 75, because they didn't move. They are still at the initial 60 lbs.
Old 04-09-2018, 01:34 PM   #11
Flathead
Flathead's Avatar
If the nuts are stuck on the threads you don't really know what the torque is.
Flathead is offline   Reply With Quote
Old 04-09-2018, 07:26 PM   #12
Smog Tech
Smog Tech's Avatar
I use ARP Ultra-Torque Assembly Lube on head nuts. Nuts don't stick to the threads.
I worried about the nuts loosening, but that a has not happened yet.
I torque Model A heads to 55 lbs.
Smog Tech is offline   Reply With Quote
Old 04-10-2018, 05:51 AM   #13
James Rogers
The only time I found a head gasket (copper) that didn't compress after a heat cycle is when an old gasket was re-used. They don't compress because it is compressed as much as possible. Gaskets can be re-used BUT, not on a new customer engine without the customers knowledge.
