#21 |
I used the modern style head gasket for my model a original motor and it worked well, stopped all seepage. Installed it about 8 yrs ago...JD
#22 | |
![]() Quote:
"ABOUT HEAD GASKETS: Our Best Brand head gaskets do not require "sealant" if the decks are flat, near-new, fresh, unscored and clean. Sealant is built into the gasket. Name goes to up to sky. Start Torque at 25 pounds, using the sketch above, in numerical sequence and increase incrementally 5 pounds at a time to a final torque of 55 pounds." I have a Snyder's 5.5 on my '30 Town Sedan using a Best 573G gasket. No sealant, no problems. |
#23 |
Pertaining to water droplets at the tailpipe----don't forget that water is a by-product of combustion and some water is perfectly normal.
#24 |
^^^Not only that,^^^ grey iron castings crack...
#25 |
Flathead is correct, when you burn gasoline, water is a product of combustion.
The Best website says to use copper spray on their graphite head gaskets. I do and it works well. |
#26 | |
#27 |
yup! it took me 3 weeks to get my head off! the studs where stuck to the head
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#28 |
I don’t think anyone sells the 509 G anymore, as it only fits an A. The venders seem to sell the 573, which is for a B with the steam holes. So it will work on either a B or an A. That’s the one recommended for the high compression head.
#29 |
Graphite doesn't bond. It is an excellent high temperature lubricant. If your head is in good condition, flat and not warped, and without cracks I would recommend using a copper gasket. The key to making a Model A gasket not leak is to torque, torque, and retorque the head frequently after installation. Doing this is key to preventing leaking.
#30 | |
![]() Quote:
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#31 |
The copper ones use graphite.
http://www.bestgasket.com/about_our_products.asp "GraphTite™ head gaskets have superb sealing characteristics, excellent torque retention, and hold up to the punishment dished out by high-performance engines" |
#32 |
'29er' seems to have covered most everything I could think of and more. Senior Members have those years of experience that cannot be gained any other way.
