Old 03-09-2018, 09:53 PM   #1
Art Newland
Art Newland's Avatar
Default Flywheel ring gear
Are all the starter ring gears the same in the 8BA family? Everything I've seen for sale mentions 112 teeth.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 03-09-2018, 10:33 PM   #2
Brian
Brian's Avatar
Default Re: Flywheel ring gear
Yes; 32-53 all share the same ring gear. Flywheels change through the years; not so the ring gears.
Old 03-09-2018, 11:42 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
NOT TRUE! The ring gears are different between late and early style. I've posted pics before on this...I'll try to post 'em again tomorrow. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-10-2018, 12:10 AM   #4
Ken/Alabama
Ken/Alabama's Avatar
The 32-48 ring gear is wider than the 49-53
Old 03-10-2018, 12:28 AM   #5
Dick Webber
I think the 6 has a different starter gear as well
Dick Webber is offline   Reply With Quote
Old 03-10-2018, 12:45 AM   #6
Brian
Brian's Avatar
Sorry! I obviously gave wrong info
Try this; B 6384- gear -flywheel ring 28-48 pass and trucks [except 60 HP] used on trucks to serial # H48-20001
8BA 6384 A gear-flywheel ring-pass 49, trucks 48-49 from serial # H48-20001
Old 03-10-2018, 12:59 AM   #7
flatheadmurre
flatheadmurre's Avatar
Tooth count and outer diameter on the v8 are the same innner diameter are different between 8BA and earlier engines.
Straight engines are different to.
Old 03-10-2018, 11:03 AM   #8
Art Newland
Thanks a lot for the info. My 49 F1 has never sounded very good while cranking. while I have the engine out I want to change the ring gear and starter drive. So it looks like whether it's car or pickup, Merc or Ford they are the same?
My pickup has a 9.5 inch clutch so I presume it's from a car?
Also noticed the stamped starter mount/flywheel cover has been welded so it could possibly be an alignment issue.
"whatever works!"
Old 03-10-2018, 06:35 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
As promised, here's the pics.....early and late! DD
T5 W/TORQUE TUBE
Old 03-10-2018, 07:04 PM   #10
Art Newland
Thanks!
"whatever works!"
