Old 02-25-2018, 09:21 AM   #1
t35
Cool 1935 ford ring job
my 35 has a 36 engine with inserts.
i'm concerned about getting a massachusetts(new inspection laws) sticker, since it does put out some smoke. when i last had the cylinder heads off there was very little ridge on the cylinder walls.
i would like to try doing a ring job with engine in the car since i only drive about 1,000 miles per year.
any thoughts on the practicality?
does anyone know a way around doing anything?
t35 is offline   Reply With Quote
Old 02-25-2018, 09:55 AM   #2
alanwoodieman
Default Re: 1935 ford ring job
first check compression, next maybe put in PCV valve in the breather system
Old 02-25-2018, 10:35 AM   #3
Brendan
Brendan's Avatar
i dont think i would be good on a 35 motor. you will suck dirt in through the vent in the oil pan
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-25-2018, 10:44 AM   #4
t35
compression is between 85 and 95 with all plugs out.
would i put pcv it in the breather tube?
are there any ready made kits?
i don't have an oil filter.
Old 02-25-2018, 11:04 AM   #5
JSeery
JSeery's Avatar
As Brendan pointed out, a 35 Ford flathead does not have a rear seal on the crankshaft. A PCV setup will create a negative pressure inside the engine and draw air in around the crankshaft. That air is coming from the flywheel/pressure plate/clutch area. I would not want to draw than unfiltered are into an engine.
Old 02-25-2018, 02:53 PM   #6
1931 flamingo
1931 flamingo's Avatar
Before doing a ring job I'd run it through the inspection station first and see if I pass or not. FWIW
Paul in CT
Old 02-25-2018, 03:07 PM   #7
oldford2
oldford2's Avatar
Massachusetts emission rules do not apply to your car. If the brakes, lights, front end are good and it drives to your satisfaction you should be good for a sticker. Before you take it in talk to the inspection station and see if my thoughts are correct. Doesn't hurt to ask.
Maybe MMO and 100 miles of driving will clean the rings and diminish the smoke
John
oldford2 is offline   Reply With Quote
Old 02-25-2018, 03:51 PM   #8
AnthonyG
AnthonyG's Avatar
:That's why God made STP High Mileage Oil Treatment
Nomad
AnthonyG is offline   Reply With Quote
Old 02-25-2018, 04:16 PM   #9
t35
they are now rejecting even older cars for smoking exhaust. been in effect since oct 2017.
they also now have cameras in inspection bays.
Old 02-25-2018, 05:04 PM   #10
rotorwrench
rotorwrench's Avatar
The MMO in the fuel can help with some driving under power to reduce carbon in the rings & valves. If it has been smoking for a while and still does so after warm up, it may be time for a re-ring. I personally don't like doing an in car partial O/H but folks did it for years with limited success. When ever I did worn cylinder ring jobs, I usually had the best luck with Hastings rings if they still make them for the old buggers. Ream the ridges and do a good hone with a ball type flex hone. If the cylinder wall wear is beyond specs for a bore job then results can easily be unsatisfactory.
Old 02-25-2018, 05:44 PM   #11
t35
it seems that hastigs rings are still available nos at different oversizes.
now i have to carefully gauge each cylinder, no telling what's been done with this engine.
i think i remember old mechanics doing one piston at a time while in car.
Old 02-25-2018, 06:16 PM   #12
JSeery
JSeery's Avatar
No idea why you would do one piston at a time. But the big issue is keeping the honing debris out of the engine.
Old 02-25-2018, 06:35 PM   #13
rotorwrench
I always use soap & water with a stiff brush after the hone. The oil pan would be off anyway but the crankshaft would need a good careful cleaning too. There is always a risk doing work in situ. That's why I don't.
Old 02-25-2018, 06:38 PM   #14
oldford2
oldford2's Avatar
Now is this something you had a discussion with the inspection station??
Old 02-25-2018, 07:49 PM   #15
Ggmac
I just got done building a 36 steel piston motor . Check carefully near the very top of the cylinder . The steel piston has a very high ring location . If there's no finger nail catching ridge , still remove what is there before pushing Pistons . Don't use a carbide ridge cutter , if you do be VERY careful not to cut below the upper piston ring location . It's best and easiest to just hone the small ridge out .
When you buy piston rings make sure you buy them for steel Pistons .
I can email you a pic of how high the ring is to get an idea of what I'm talking about .
Gary
Old 02-25-2018, 07:55 PM   #16
t35
oldford2 yes. new laws since oct 2017...............can you check with your local stations?
Old 02-25-2018, 08:13 PM   #17
russcc
Mass inspection is a pain in the butt. They now take photos of your odometer, license plate. I have yet to have the hot rod or the 40 inspected, so we will see what happens. The guy I go to is an old drag racer who wrenched on a funny car. Any one in Mass had a vintage car inspected since 10/17 ?
Old 02-25-2018, 08:27 PM   #18
t35
Gary
yes i would appreciate the pic...
Old 02-26-2018, 06:16 AM   #19
Ggmac
I'll send you a pm . I'll need your email , that the only way I know to send pics .
Gary
Old 02-26-2018, 04:55 PM   #20
40 Deluxe
You're not working on the space shuttle! These engines have run well for years with low budget repairs. Go for a re-ring job. First mike the cylinders to see what oversize, if any. Or scrub the top of a piston to see what oversize. Parts stores like O'Reill'ys, Autozone and Advance loan tools like ridge reamers, cylinder hones, ring compressors and torque wrenches. You can find inexpensive mikes on ebay, etc. if you feel the need to measure. If the cylinder walls are smooth (light scratches are OK), just cut the ridge, push out the pistons, tape over the oil holes in the crankshaft, hone the cylinders, clean everything and reassemble. Good to go!
I've had good results just putting rings in cylinders with as much as .019" taper. At only 1,000 miles a year, you should be good for 15-20 years.
