Old 01-31-2018, 05:19 PM   #1
charlesea
charlesea's Avatar
Default Brake shoes
What us the difference between Model A brake drum and hydrolic brake drum for a Model A?
Thanks in advance.
Charles
charlesea is offline   Reply With Quote
Old 01-31-2018, 05:20 PM   #2
charlesea
charlesea's Avatar
Default Re: Brake shoes
I meant to say Brake drums.
Old 01-31-2018, 08:09 PM   #3
redmodelt
redmodelt's Avatar
diameter, shoes and backing plates for starters. They are are larger in diameter then the A stuff.
Old 02-01-2018, 12:01 AM   #4
midgetracer
midgetracer's Avatar
Also, the A drum is steel, and the hydraulic drum is cast iron.
midgetracer is offline   Reply With Quote
Old 02-01-2018, 12:51 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
In mid 31 Ford went to cast iron drums The original spoked cast iron front drums were made as one piece with the hubs . The original cast rear drums mostly looked like the new cast rear drums . The original Cast drums were what we use to call cast steel, they would usually bend rather than crack like some of the cast iron drums sold now . I've never cracked or bent any of them . The new cast iron drums are fine for me , if I was buying new .
Old 02-02-2018, 12:35 PM   #6
Ron in Quincy
Ron in Quincy's Avatar
The brake system on the A is 60 percent on the rear and 40 percent on the front, when the rears lock up the front will still turn with force,
Hydraulic brakes are just reverse, the shoes in the front are larger and the fronts are 60 percent and the rears are 40 percent.
If you are re-doing your brakes I would suggest you use cast iron drum for mechanical or hydraulic.
Ron
Ron in Quincy is offline   Reply With Quote
Old 02-02-2018, 12:45 PM   #7
V4F
V4F's Avatar
I'm using 1942 hyd . yes the drum is larger & my brake shoes are only for 1942
V4f
V4F is offline   Reply With Quote
