Old 01-21-2018, 03:01 PM   #21
Ol' Ron
Ol' Ron's Avatar
Default Re: milling iron heads
The original CT L-100 had .375 for both intake and exhaust. with .016 clearance, Thus aprox .360 net lift. However, on a reground stock cam, allot of material is removed from the base circle to get that much lift. I consider any cam over .350 net lift a hi lift cam. again the Isky 400jr ground on a billet would still have allot removed from he base circle due to the fact it must fit through the cam bearings. I'm also Conservative when I build a street engine. I look for reliability and economy, anlong with long life. Thus 50 lbs of valve spring pressure.
Old 01-21-2018, 03:18 PM   #22
Ol' Ron
Ol' Ron's Avatar
Old 01-21-2018, 03:31 PM   #23
hardtimes
hardtimes's Avatar
Hey Ron,
Was 50 lbs stock seat pressure on a factory engine ?
Old 01-21-2018, 03:58 PM   #24
B-O-B
B-O-B's Avatar
Here is the spec sheet on my cam grind L100
B-O-B is offline   Reply With Quote
Old 01-21-2018, 06:22 PM   #25
flatjack9
flatjack9's Avatar
The sheet specs lobe lift, so you need to subtract .014 to get actual lift at the valve.
Old 01-21-2018, 06:31 PM   #26
JSeery
JSeery's Avatar
Originally Posted by hardtimes View Post
Hey Ron,
Bob C posted the factory specs a day or two ago.
"I found these valve specs in the Ford truck service manual, I think the car
would be similar.
1949-50 Test Length 2.13" 37-40 lbs
1951 Test Length 1.89" 40-43 lbs"
Don't believe any factory spec was in the 50lb range, that would have been a "Hot Rod" number.
Old 01-21-2018, 08:36 PM   #27
Ol' Ron
Ol' Ron's Avatar
use a stock spring with a .060-" shim, this gives between 50/55 lbs
Old 01-22-2018, 02:01 AM   #28
hardtimes
hardtimes's Avatar
would be similar.
Very good specs, thanks much !
Old 01-22-2018, 02:03 AM   #29
hardtimes
hardtimes's Avatar
Thanks much for sharing this information !
Old 01-22-2018, 05:34 AM   #30
51 MERC-CT
51 MERC-CT's Avatar
Just to clarify, would that be with the longer (Chev.) valves?
Old 01-22-2018, 09:19 AM   #31
40cpe
40cpe's Avatar
My experience: I used the chevy valve and LZ springs from Red's Headers with the keeper in the bottom slot. Jim said the springs would give about 80# on a stock valve. I used one .060 shim all the valves and an additional .010" on some to get 45# to 52#.
Old 01-22-2018, 10:13 AM   #32
flatjack9
flatjack9's Avatar
That's been my experience also.
Old 01-22-2018, 11:03 AM   #33
Kahuna
Kahuna's Avatar
I was able to find a new set of Canadian aluminum heads, as I wanted the appearance of stock heads. Then had them modified after a lot of measuring to accommodate a high-lift
Potvin 425 cam. They seem great, but now I think I would rather have the finned heads for the appearance.
Jim
Kahuna is offline   Reply With Quote
