Old 12-23-2017, 10:47 AM   #1
Roadster62
Roadster62's Avatar
Default 1939 Ford Truck Cab Wood Kit Needed
Who makes a cab wood kit for a 1939 Ford Truck Cab? The body to frame blocks. Thanks! Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-23-2017, 11:57 AM   #2
sidevalve8ba
sidevalve8ba's Avatar
Default Re: 1939 Ford Truck Cab Wood Kit Needed
Mack Products offers a cab mounting kit.
http://mack-products.com/products-page/ford-wood/
sidevalve8ba is offline   Reply With Quote
Old 12-23-2017, 05:06 PM   #3
Roadster62
Roadster62's Avatar
Thanks! I hope they can send a photo before I send payment. Has anyone used their wood kit, is the quality good? Photo of my cab bottom. Bob
https://www.jalopyjournal.com/forum/...6-jpg.3391851/
Old 12-23-2017, 06:58 PM   #4
51504bat
51504bat's Avatar
Westcotts Auto in Oregon lists them:
http://www.wescottsauto.com
Old 12-23-2017, 07:21 PM   #5
39portlander
39portlander's Avatar
Bob a word of caution on the cab wood, there are some 39's with the left over style more like a 38/39. Sometime in mid 39 the wood changed and there is 39-41 style.
I went through this with the late great Dick Spadaro, lots of left over parts used on these trucks so check your old wood with the new versions available.
39portlander is offline   Reply With Quote
Old 12-23-2017, 10:17 PM   #6
Roadster62
Roadster62's Avatar
Thanks! I looked up that old post and most of the photos are lost to the Photobucket me$$. Sure do miss Dick Spadaro. I'll round up whatever pieces I had when I started to take things apart, I'd rather buy a kit than make one from scratch. Bob
Old 12-24-2017, 02:16 AM   #7
freddie
freddie's Avatar
Hi, If you are referring to a truck, are you referring to a 1/2 ton pickup or a 3/4 or 1 ton truck. There are no cab wood kits available for the 3/4 and 1 ton ton trucks. I have drawings for these wood pieces which I can provide (1940/1941) which is used on the 3/4 and 1 ton trucks.
freddie is offline   Reply With Quote
Old 12-24-2017, 09:47 AM   #8
Roadster62
Roadster62's Avatar
OK, All this time I thought the same cabs were used on pickups and the big 3/4 and ton trucks. My cab was on a rack body one ton I believe, has the gas tank filler on the passenger side. I'm building a pickup with this cab, and a stock frame. Bob
Old 02-01-2018, 11:11 PM   #9
Roadster62
Roadster62's Avatar
Is there any new info on cab mounting wood for a 1939? I picked up a frame and would like the get started. Bob
Old 02-02-2018, 10:43 AM   #10
51504bat
51504bat's Avatar
As I understand it the cabs are all the same but the frames are different between the 1/2 ton pickups and the 3/4 ton and larger "big trucks" hence the difference in mounting blocks.
Old 02-02-2018, 03:47 PM   #11
V12Bill
V12Bill's Avatar
I have a '39 and replaced the wood. Mine did not have wood going lateral across the cab, only the frame to cab side pieces. I forget the name of the supplier that I got the wood from.
V12Bill is offline   Reply With Quote
Old 02-05-2018, 03:51 AM   #12
freddie
freddie's Avatar
If you send me your e-mail I will send you the drawings!
Old 02-05-2018, 04:04 AM   #13
flatheadmurre
flatheadmurre's Avatar
I have used http://www.horkeyswoodandparts.com.
Made inhouse excellent quality and Bruce is a very nice guy to deal with.
You got drawings he will probably make what you want on custom order to...give him a call and check.
Old 02-23-2019, 04:13 PM   #14
Dan 1939
Dan 1939's Avatar
Do you still have drawings of the wood for between the cab and frame. A friend of mine that is not a member asked me to look for this information. He has a 1939 1/2 ton truck.
Please email to [email protected]
Thank you for your help.
Dan
Dan 1939 is offline   Reply With Quote
Old 02-24-2019, 10:23 AM   #15
39portlander
Bob I see this thread has reappeared, I still have the original wood from my restoration and could ship them down to you to use as templates.
I have the later year and grooves for the cab to set and finger joints that extend the wood pieces to the bed. Let me know If that will help get you started.
