Old 11-12-2017, 08:06 AM   #1
Magoo2
Default Spark and control rod interference
Has anyone had this problem? After reinstalling the closed cab on my 31 pickup I started reassembling the other components. I never removed the drivetrain or steering column.Everything went together fine but when I went to install the throttle control rod it interferes with the starter switch shaft. I also noticed that the spark control rod rubs on the engine. Anyone have any ideas or experience with this?
Magoo2 is offline   Reply With Quote
Old 11-12-2017, 08:47 AM   #2
jw hash
jw hash's Avatar
Default Re: Spark and control rod interference
what body do you have. on the ones with the drop steering column, like the Victoria and A400. the spark rod does rub on the head and the throttle rod has a bend in it to clear the starter rod.
jw hash is offline   Reply With Quote
Old 11-12-2017, 10:10 AM   #3
burner31
burner31's Avatar
Loosen steering column clamp on the steering box, loosen the column clamp on the dash.
Turn/adjust column as needed.
Retighten clamp on steering box THEN the column clap under the dash.
Done
Keith
Shawnee OK
'31 SW 160-B
Old 11-12-2017, 10:29 AM   #4
mike657894
mike657894's Avatar
On my car the spark advance rod rubs the head slightly. When i got the car it had an arced bow to it that affected performance but cleared the head.
mike657894 is offline   Reply With Quote
Old 11-12-2017, 10:44 AM   #5
katy
katy's Avatar
Frame sag?
