Old 10-23-2017, 10:57 AM   #1
Jim M
Jim M's Avatar
Default Ujoint
I just rebuild my original Ujoint and it came out beautiful. Have not put it in yet but now hesitant. Something I was looking at over the weekend mentioned balancing a Ujoint. I had not heard of balancing the joint and now thinking of the driveshaft as well. Any ideas or helpful hints while I have everything apart? Looking forward to getting it back together and going for a drive but NOT looking forward to taking it apart again for a while....lol. Thanks, Jim
Jim M is offline   Reply With Quote
Old 10-23-2017, 11:18 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Ujoint
Nope, not an issue. Forget it
Old 10-23-2017, 11:44 AM   #3
ursus
Default Re: Ujoint
Did you assemble the two halves of the U-joint in the same orientation as it was before? That should assure balance.
Old 10-23-2017, 09:54 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ujoint
I wouldn't worry about it. Just be sure it has lots of grease. I pack them full.
Old 10-23-2017, 09:58 PM   #5
1930-Pickup
Default Re: Ujoint
Balancing the shaft is common with open drive lines, but not with closed drive lines.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
