Old 09-10-2017, 02:12 PM   #1
James G.
Default Stainless exhaust pipe rattle won't stop!
I've not resorted to building a "modern rubber/hanger and those "clamps for stainless exhaust" only work for a short while.
QUESTION - what can happen if I just resort to the original clamp Ford used and just clamp the stainless pipe down??? does it put the manifold casting in danger of cracking???
So tired of that dadburn rattle and I'm not about to do away with my stainless exhaust!!
James G. is offline   Reply With Quote
Old 09-10-2017, 02:22 PM   #2
Dodge
Default Re: Stainless exhaust pipe rattle won't stop!
Stainless steel grows in length when heated as in the exhaust system. You need to figure
that in. The clamp needs to let it expand.
In some cars the exhaust will grow several inches.
Dodge is offline   Reply With Quote
Old 09-10-2017, 02:28 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Good morning, Dodge. Does S/S "grow" more than regular exhaust pipe? I don't have S/S exhaust, just askin' for my own knowledge and future reference. Thanks
Old 09-10-2017, 06:07 PM   #4
eagle
eagle's Avatar
In general (10-6 in/in/ deg F)
Carbon Steel (1020) 6.7
Grey cast iron 6.7
Stainless (304) 10
Aluminum 13 Highest
Copper 9.3
Manganese-bronze 11.2
Titanium 5.0 lowest
Gold not listed in the book I checked
In reality these numbers are just guidelines, the thermal expansion of can vary quite a bit depending on the alloy. Silicone for instance reduces the thermal expansion of aluminum significantly. The thermal expansion rate also changes somewhat depending on the temperature of the metal.
(Googled)
Old 09-10-2017, 07:08 PM   #5
Tacoma Bob
Tacoma Bob's Avatar
MMMMM been runnin a S/S aries for years with a re-pop hanger. I did have to fiddle with it I bit but have run for years with no problems.
Tacoma Bob is offline   Reply With Quote
Old 09-11-2017, 10:23 AM   #6
katy
katy's Avatar
What does "In general (10-6 in/in/ deg F)" mean?
Old 09-11-2017, 11:18 AM   #7
Jim/GA
Jim/GA's Avatar
I purchased an oversize muffler hanger with woven insulation inside it with my S/S muffler. That lets the tailpipe move when it gets hot but does not rattle.
Bratton's part number 7131. I'm sure other vendors have the same thing.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 09-11-2017, 03:15 PM   #8
Nathan_1929
Nathan_1929's Avatar
No way, unless it's made out of rubber.
Sounds like he's describing the coefficient of thermal expansion (CTE) for different metals. 10^-6 is scientific notation, and in/in is the unitless coefficient, per degree F. Another way of looking at it is as microinch per inch per degree F.
So, he's saying the CTE for stainless is 0.00001 in/in per degree F. What I'm seeing elsewhere is, based on the alloy of stainless, linear CTE is somewhere between 5 to 10 * 10^-6 /deg F.
What does this tell us? Someone should just measure their tail-pipe hot and cold based on a known datum and tell us how much it lengthens. I'd guess very little.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 09-11-2017, 03:19 PM   #9
JBill
Aries calls for care with a "not too tight" exhaust hanger even with the regular steel muffler, so apparently it's not just the stainless steel expansion they're concerned about.
JBill is offline   Reply With Quote
Old 09-11-2017, 07:49 PM   #10
brianpharmd
brianpharmd's Avatar
I have a S/S Aries exhaust on my coupe and a standard Aries on my sedan. Both have the oversized tailpipe hanger for expansion. Both had the flimsy thermal cloth which lasted all of 100 miles. I bought some exhaust pipe wrap from the auto store. Not is as wide as the clamp but not very thick. I could it to fit the circumference of the clamp. Attached it with red RTV and let it dry. Then I attached the clamp with the pipe in place. Snug but still let's the pipe expand. Also rooming my rattle at the end of the tailpipe. Check Amazon for the exhaust pipe wrap. May be cheaper than the auto parts store. Send me a PM if you need pictures.
Brian
brianpharmd is offline   Reply With Quote
Old 09-11-2017, 07:54 PM   #11
brianpharmd
Originally Posted by brianpharmd View Post
I have a S/S Aries exhaust on my coupe and a standard Aries on my sedan. Both have the oversized tailpipe hanger for expansion. Both had the flimsy thermal cloth which lasted all of 100 miles. I bought some exhaust pipe wrap from the auto store. It is as wide as the clamp but not very thick. I cut it to fit the circumference of the clamp. Attached it to the clamp with red RTV and let it dry. Then I slid the clamp over the pipe and tighten in place. Snug but still lets the pipe expand. Also eliminated my rattle at the end of the tailpipe. Check Amazon for the exhaust pipe wrap. May be cheaper than the auto parts store. Send me a PM if you need pictures.
Brian
Auto correct/word substitutions on the tablet makes my post look atrocious. I fixed it in this post.
Old 09-11-2017, 11:26 PM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I used some welded cloth
Old 09-12-2017, 09:13 AM   #13
katy
katy's Avatar
Nathan, thanks for the explanation, but I'm still confused.
I took high school math in the '50s and don't understand the "modern" symbols and ways of expressing mathematical equations.
Old 09-12-2017, 11:18 AM   #14
midgetracer
midgetracer's Avatar
Katy what he is saying is that the pipe expands in length .000001 inches per inch/ degree F. this means that for a length of 10 ft (not a real measurement of a model A muffler) and a temperature increase of 100 degrees F (10 ft =120 inches) therefore, 120 inches X 100 degrees X .000001 =.12 inches expansion in length for the exhaust pipe and muffler. Not very much is it?
midgetracer is offline   Reply With Quote
Old 09-13-2017, 09:46 AM   #15
katy
katy's Avatar
I understand co-efficient of thermal expansion, but what I'm trying to get my head around is what 10-6 in/in/ means.
10 minus 6 equals 4, that's pretty simple, but then what does in/in/ mean?
Old 09-13-2017, 10:53 AM   #16
midgetracer
something times 10 to the minus six equals moving the decimal point 6 places to the left.
Old 09-13-2017, 11:23 AM   #17
Nathan_1929
"10^-6" is scientific notation for 0.000001. "in/in" is a way of saying "this is a unitless coefficient." Per degree is as stated.
That way, you can multiply your original length of material by a tiny coefficient specific to that material and arrive at what happens during a temperature change.
As midgetracer says;
The material expands in length .000001 inches per inch/ degree F.
Where CTE = .000001, x = 120 in, deltaT = 100 deg:
deltaX = .000001 * 120 in * 100 deg = .12 in.
To double check our logic, the units are:
(in/in /deg) * (in) * (deg) = (in*in/in)*(deg/deg) = in.
Makes sense.
But like I said several posts ago, someone should just measure the end of the tail pipe against a known datum at hot vs cold and see how little it actually moves.
Old 09-14-2017, 04:14 AM   #18
dumb person
dumb person's Avatar
A mild steel one moves about 5mm in my experience. Enough that it will permanently distort if the clamp was welded on and not the slip fit kind...
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 09-14-2017, 09:13 AM   #19
katy
katy's Avatar
Thanks all for the replys to this old fart, I think I'm starting to understand this scientific notation stuff a little bit. I tried a web search and still didn't find much stuff in plain words that I could understand.
Old 11-17-2024, 11:52 PM   #20
amuffler
if your problem is not solved call me for a free clamp designed to do the job. Free 650-279-6609 west coast
amuffler is offline   Reply With Quote
