Old 08-19-2017, 09:56 PM   #1
Cape Codder
Cape Codder's Avatar
Default Saving Private Messages
I have several, actually a lot, of private messages that I would like to save as I am at 493 right now. How can I save these other then copy and past them all into say Microsoft Word?
Cape Codder is offline   Reply With Quote
Old 08-19-2017, 10:18 PM   #2
wrndln
Default Re: Saving Private Messages
I'm not sure you can save them on Fordbarn.
Rusty Nelson
Old 08-19-2017, 10:49 PM   #3
fordcragar
fordcragar's Avatar
If you go into your PM's and on the right side of each message there is a box that you can click on, to select it. Or at the top of the boxes on the right side, you can click on a box there that will select all of the messages. After you have selected your messages, drop down to the bottom of the messages, and still on the right side there is a drop down box that will give you several different options, where you can download your messages into several different formats. After you have downloaded your messages, you can use the same drop down box to delete them. Hopefully this isn't to confusing, but it is fairly easy.
fordcragar is offline   Reply With Quote
