Old 08-06-2017, 10:04 AM   #1
Dave1931Pickup
Default Transmission Shift Fork Pins
Hi Everyone, What is a good method for backing up the head of the shifting fork pins for upsetting the hollow head. So far I have tried various chisels, screwdrivers and chunks of steel only to find that I need six hands and more patience. Also after they are upset it appears that they would still be loose. Is that right. I've heard a few people say to use roll pins, but I want to do it the way Henry did it.
Thanks for your help, Dave
Dave1931Pickup is offline   Reply With Quote
Old 08-06-2017, 11:12 AM   #2
Brian T
Brian T's Avatar
Default Re: Transmission Shift Fork Pins
Hi Dave,
I have been there a few times with success, but find the roll pins a better option, do not remember the size.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 08-06-2017, 11:40 AM   #3
1955cj5
1955cj5's Avatar
I did it the first time with rivets, but they never would tighten up...always a little movement in the shift forks.
I made a bucking tool that held the heads and fit tightly in the case, but it seemed the available rivets did not have a deep enough recess in the end to allow them to tighten properly.
I used the roll pins the second time when I changed to a front mount brake handle.
Much better..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-06-2017, 12:04 PM   #4
sjhark
sjhark's Avatar
I just finished this job last week. I took a pair of Crescent brand slip joint pliars and adjusted them so they clamped against the head of the rivet and the opposite side of the fork, with the handles almost closed. I then clamped the handles together with a pair of vice grips and used a hammer and large center punch to spread the end of the rivet. Worked like a charm.
Old combat adage: if it looks stupid, but it works, it's not stupid!
If earthworms had machine guns, we'd all be in trouble!
sjhark is offline   Reply With Quote
Old 08-06-2017, 01:02 PM   #5
1955cj5
1955cj5's Avatar
The factory must have had a tool like your pliar/vice-grip combo. Maybe more like a vice-grip with a forked jaw to clamp the rivets tight before setting...
Old 08-06-2017, 01:49 PM   #6
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Place a punch in the hollow end and roll it around to make the hollow end larger..
Dick M is offline   Reply With Quote
Old 08-06-2017, 02:08 PM   #7
2manycars
2manycars's Avatar
Hardened split pins (sometimes called roll pins) work the best. Easy to install and a tight fitting fork when done.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-06-2017, 05:46 PM   #8
Dave1931Pickup
Much better..
I agree about the available rivets not having deep enough recess to tighten up. I'm sure that the factory had a special tool like sjhark made.
Thanks everyone, I'm switching to 3/16" X 1-7/8" roll pins.
Old 08-06-2017, 07:37 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Dick M View Post
Place a punch in the hollow end and roll is around to make the hollow end larger..
Yep, that's how I do them, and it works great.
Old 08-06-2017, 10:50 PM   #10
Russ/40
Russ/40's Avatar
I decided on roll pins. Not 100% comfortable with that, I ran safety wire through the roll pins and around the fork shaft. They weren't going anywhere.
Old 08-07-2017, 04:20 AM   #11
31 RPU
Russ,
I did the same thing.
I took a dermal tool and made a groove on the opposite side of the split in the pin for the safety wire to lie in.
31 RPU is offline   Reply With Quote
Old 08-07-2017, 10:17 AM   #12
Russ/40
Russ/40's Avatar
Originally Posted by 31 RPU View Post
Russ,
Even better yet! Great idea!
Old 08-08-2017, 09:18 PM   #13
Dave1931Pickup
I screwed up. The proper roll pin is 3/16" X 7/8" not 1-7/8".
Sorry for the bad info, Dave
Old 05-06-2025, 10:48 AM   #14
tommymdot
I do not like the roll pins. They are not as substantial as a solid pin. It would have been easier for Henry to use roll pins too, but he built his cars to last.
I buy 3/16 X 7/8 solid steel pins and weld a head on one end.
I insert the pin in the fork assembly from the top using long neck pliers and drive it down with a punch.
Once the pin is driven home, I weld a head on the other side of the pin.
Will last forever.
tommymdot is offline   Reply With Quote
Old 05-06-2025, 12:59 PM   #15
Flathead
Flathead's Avatar
Roll pins were not available in the 30's. If they were I bet we would have seen their use on the A.
Flathead is offline   Reply With Quote
Old 05-07-2025, 11:07 AM   #16
Steve Schmauch
There is an easy solution. Take care in removing the original rivets. The flared end will close up as it is pushed upwards through the fork. To re-use the originals, I use a long thin drift placed upward in the hole and needle nose pliers to manuever the hole in the end of the pin so it slips onto the protruding drift. A screwdriver may be needed to push the pin down into its (former) position. Us a larger drift to carefully flare the end of the pin. It only needs to be loose fitting and flared only slightly, as Henry did it. Done this way the pin can be re-used several times. Really a simple job!
Steve Schmauch is offline   Reply With Quote
Old 05-07-2025, 08:46 PM   #17
Brentwood Bob
I have reused the original pins as Steve has explained. Should easily be trouble free in my lifetime, or should I say for many shifts.
Brentwood Bob is offline   Reply With Quote
Old 05-07-2025, 09:28 PM   #18
Bigsnapper43
In the kit sold by the suppliers is a very small c clamp. It has a cup for the head of the pin to set in. I would say it is a 2" c clamp. If you are rebuilding the shift housing without the kit I pitty you. Having done 15 plus units without the kit my religion was tested heavily. I bought the kit!!! No more wondering about the spring or chasing the casting on the work bench. I would not attempt the rebuild without the kit.
Bigsnapper43 is offline   Reply With Quote
