Old 08-06-2017, 09:05 AM   #1
Brendan
Brendan's Avatar
Default 36 Pickup Turtle
i have 7;50 16 tires on my pickup. there where 6;50 16 on it before. the speedo was close to being accurate, now it is not. i also have a turtle from a model a ford. it is from a 3:78 rear, could i swap them out, to get it closer, will the model a turtle bolt up?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 08-06-2017, 09:24 AM   #2
41PICUP
41PICUP's Avatar
Default Re: 36 Pickup Turtle
Which turtle do you now have on the truck?
41PICUP is offline   Reply With Quote
Old 08-06-2017, 10:00 AM   #3
rotorwrench
rotorwrench's Avatar
The tire circumference changed. Housings might interchange but each one is a bit different due to the circumference of the gears and different shafts. Speedo cable connections are different shape on the model A ones depending on year of manufacture. They are numbered for the size of the gear. You need to find the number housing you need according to the chart in the green bible. I'm pretty sure that new gears are available.
Old 08-06-2017, 10:39 AM   #4
Brendan
Brendan's Avatar
its the orignal one, 1936
Old 08-06-2017, 10:52 AM   #5
JSeery
JSeery's Avatar
That's the year, but that has nothing to do with the ratio. What you need to know is part number of the housing and the number of gear teeth it has. It will depend on the original rear axle ratio and tire size (assuming everything is factory original). The base number is 17270.
Old 08-07-2017, 10:59 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Brendan......Even though the one you have is ORIGINAL, the "turtles" were made (and NUMBERED) to correspond with the gear RATIO found in a particular vehicle. The number you see embossed on the turtle below (18) represents the number of TEETH on that turtle's gear. In the case below, 18-teeth was the number that corresponded to a 3.54 rear end along with standard-issue tire size. So, what we need to know is the EMBOSSED NUMBER on your "original" turtle before any recommendations can be made. DD
Click Links Below __
T5 W/TORQUE TUBE
