Old 07-23-2017, 09:38 PM   #1
fredski53
fredski53's Avatar
Default Think it blew up!
Well, I think I went and did it! Took the Vicky out today for a drive, on the way home I was cruising at 40/45 when she started to make a very loud pounding noise! It lasted for a few seconds then the engine stopped. Coasted to the side of the road and called the wife to help tow it home. Once home I tried to start her up, and she started right up! But now it's smoking bad. A lot is smoke coming out the oil fill cap. It never did that before. Don't hear any new engine noises, it's ticking a bit, but not bad. So, what do you think? Did it throw a rod? Break a ring? I'm not crazy about getting the engine overhauled, but of thats what it take, so be it.
fredski53 is offline   Reply With Quote
Old 07-23-2017, 09:51 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Think it blew up!
Drop the pan and have a look for metal?
www.whidbeymodelaclub.com
Old 07-23-2017, 09:57 PM   #3
H. L. Chauvin
Hi Fred,
One (1) humble opinion:
Really, not too much different than if you reported that your wife received a gift wrapped present for her birthday today from her children ..... and .... what do you think is inside?
With all of us as well "experienced" senior married, highly intelligent Model A owners on here, with years and years of wife knowledge, children knowledge, women's birthday knowledge, one can just imagine the recommendations and guess coming in ....... a watch, ear rings, necklace, ring, watch and ear rings, necklace and watch, etc., etc., and the list goes on for days.
But in my humble opinion .......... Fred already knows that the real winning answer will always be "after" the birthday package is opened.
H. L. Chauvin is offline   Reply With Quote
Old 07-23-2017, 09:59 PM   #4
Scottio57
Scottio57's Avatar
From what you describe my guess would be a piston seizure.
Scottio57 is offline   Reply With Quote
Old 07-23-2017, 10:19 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
I have the exact same thing happen to me soon after buying the car. An original Ford valve snapped off and fell into the cylinder popping a hole in the piston.
Old 07-23-2017, 10:36 PM   #6
burner31
burner31's Avatar
I think they refer to it as "an exploratory"
Going to have to crack the chest
Keith
Shawnee OK
'31 SW 160-B
Old 07-23-2017, 10:40 PM   #7
H. L. Chauvin
After finding the exact problem of all of what happened; next (2) interesting questions could be:
1. Why?
2. Who put an engine together that failed cruising at 40/45 mph ?
Old 07-24-2017, 05:45 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I would pull the engine and mount it in an engine stand, then start by removing the head, then the pan.
Don't turn the engine upside down when you remove the pan, because you want any metal pieces and grit to remain in the pan.
You'll likely wind up with at least a hone job and new set of pistons.
Old 07-24-2017, 09:20 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
In my opinion, before taking anything apart, do:
1. a compression test;
2. drain the motor oil and check for metal in the oil and the drain plug.
Using what you learn from 1 & 2, disassemble the engine accordingly.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 07-24-2017, 09:58 AM   #10
fredski53
fredski53's Avatar
Well, I slept on it last night, and I've decided to pull the engine and send it to a machine shop. I drained the oil, it was dirty, but didn't see any metal. Went to drain raderator, guess what? NO COOLANT! Oops , didn't check raderator before I went for the drive! But, in my defense, the car has a temp gauge. Temp was at 185 during the drive. But I guess if there is no water reaching the temp sender, then the gauge wouldn't be accurate! Oops, my bad! This mistake is going to cost big $$$$$!
Old 07-24-2017, 10:26 AM   #11
Jim M
Jim M's Avatar
Keep us posted. Also, if you put your town and state in your profile might help with someone close coming over to inspect/help. Guys close to me have been better than any manual!
Jim M is offline   Reply With Quote
Old 07-24-2017, 10:54 AM   #12
Bob C
Be sure to do your homework when choosing a shop and make sure they
are experienced with Model A's.
Bob
Old 07-24-2017, 11:12 AM   #13
H. L. Chauvin
Hi Fred,
All of the above helpful.
Most importantly, in my opinion, your reply no. 10 tells us you are no different than the rest of us ...... a most humble caring Model A person who honestly thought his radiator was full.
Most Model A guys would never have the intestinal fortitude and compassion to return to report not checking same prior to departure .... but your reply no. 10 is most educational for all of us ..... thanks for sharing.
Because of having thousands of most important life saving type vehicles, one simple military rule to follow is taught in military driver education, e.g., when a soldier picks up any vehicle in a military motor pool .... before driving off, first check coolant level, oil level, tire pressure, brake lights, running lights, fuel level, etc., etc. ..... with vehicles sitting idle unattended for any period of time, leaks and whatever are most common ...... not much different with our vintage Model A's ..... only takes (5) minutes or less .... can save big bucks .... never a bad idea to get in the habit of performing simple vehicle pre-checks.
Old 07-24-2017, 11:20 AM   #14
fredski53
fredski53's Avatar
Thank you all for your insight! I've found a shop in Sokie. ILL, Antique Engine Rebuilding, like what I've read about them. Has anyone ever dealt with them? It would be nice to use them because their only an hour or so drive from the house.
Old 07-24-2017, 11:33 AM   #15
JBill
They are one of the best, IMO. I've heard nothing but good about them on this board. They did my engine about ten years ago. They will do inserts if you want them.
JBill is offline   Reply With Quote
Old 07-24-2017, 11:34 AM   #16
JBill
PS: It's "Skokie," not Sokie, which you probably won't find on the map! Northwest suburb of Chicago.
Old 07-24-2017, 12:12 PM   #17
H. L. Chauvin
Good advice ..... names may be important at times:
Just in case you find a Model A Engine Re-building Company .... or .. an engine Re-building Company in a town with a name like "Soakie" ....... might be wise to be careful !
Old 07-24-2017, 02:15 PM   #18
Ernie Vitucci
Ernie Vitucci's Avatar
Go on line to the 'Model A Restorers Club of America' and see where the nearest club you is, and then contact them, and ask who does their engines...Ernie
Old 07-24-2017, 02:35 PM   #19
Bruce Adams
Bruce Adams's Avatar
Antique Engine Rebuilding is in Skokie IL and they did well by me in selling me a rebuilt engine. I see you are in Indiana which I guess is not all that far from Illinois if that comes into play. Best of luck !
Bruce Adams is offline   Reply With Quote
Old 07-24-2017, 02:38 PM   #20
Bob C
If you are using Antique Engine Rebuilding here's a video by them.
https://www.youtube.com/watch?v=N5kDrtTJGsU
Bob
