after reading all the posts about corn head grease I finnaly picked up a tube and filled the steering gear, same thread on grease gun took out a cover bolt and pumped until new grease came out hopefully this will stay in!
Keep us posted on your results!
www.whidbeymodelaclub.com |
It worked real well for me, saw a very big improvement and haven't leaked anything out of the steering box since. Noticed the better steering right away.
Try it in u joint to. If u joint has not been services in a long time, could take a lot of Cornhead grease.
#5 | |
![]() Quote:
Note that the same version U-joint is used on modern cars without a spherical cover and frequently without even a coat of paint. Joe K
Shudda kept the horse. |
Seems the farm tractor guys dont think much of it,but what do they know ![]() |
Look at how old that thread is. Who knows what condition those gear boxes were in before the corn head grease got pumped in. My thought is if it leaks what is supposed to be in there, fix it. Otherwise the cornhead grease is a patch.
#8 | |
![]() Quote:
Should be easy to fab one yourself. Easier to buy one. http://www.snydersantiqueauto.com/st...sing-end-plate |
I just replaced my Universal Joint (because of poor lubrication...my fault completely). After doing a lot of research I used Corn Head Grease. My only complaint is that with so little farm land left in my area no one local carries it. I had to order it on-line and paid more for shipping than the grease. Still it was worth it.
I just wish that Bratton's, or Snyder's, or one of them would carry it. I hadn't thought of it for a leaky steering box, but it sure seems reasonable to me. Ken
Style beats speed any day, and with a lot fewer tickets. |
I agree with lubing all the tie rod and steering balls on the front end. That helps so much in turning if all those moving parts are slick and nice.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
Bear in mind that "what is supposed to be in there" is based on 80+ year old lubrication technology and it's not a stretch by any means that something available today could be far and away better than what was available then IMO. Point being that just because something was the recommendation of the day 80 years ago, does not automatically mean it's the best product available today.
Good point Licensed. After all, who would run non detergent oil in there engine - not me. Sorry didn't mean to change the subject...
#13 |
So you can grease the steering box instead of putting in 600w oil. Is there a zerk??
#14 |
we put 50 miles on yesterday so far no leaks. I think what I will do is put a few squrits of corn head grease in the steering gear every time I grease the car there is no draw back to over greasing that I can see it will just go up the column. maybe for 4 bucks a tube it would be best to grease everything with corn head grease?
#15 | |
![]() Quote:
People say grease gets pushed out of the binding surfaces in a steering box and doesn't flow back inbetween the metal, so people don't use normal wheel bearing grease. The steering box doesn't get hot like the wheel bearings. Supposedly cornhead grease still flows because it is a semi liquid grease.
#16 | |
![]() Quote:
#17 |
This stuff works so good I put it on my hot wieners. After lots of research Ive learned that John Deere Had this grease specially formulated for leaky gearboxes on their farm equipment. Ive watched a video of this stuff in a large gearbox in action with the top of the gearbox removed so you could witness it. will not push off, separate, and is self leveling. Stopped my gear box leak completely. I have used STP full shot and it leaked real slow and is a PITA to clean off. picked mine up at a local John Deere dealer close by for $ 2.50
#18 |
Must be fun steering in the cold weather ,as it is with 600w in the transmission ...Talk about double clutching in the winter
"I can't cry as long as I know the Lord has risen " |
#19 |
I wish I could find it for $2.50 a tube.
![]() Now my early 29 steering box a 7 tooth has original fittings on it and I've seen others the same way. What did they have on them originally? The original fittings don't have balls and springs on them to keep the grease from squirting back out. But there should be a vent on the top? Yes...no? |
#20 |
The original "zerk" fittings in seven-tooth boxes were not intended for chassis grease. Ford dealerships had a pump that dispensed the 600w style lube into the steering box under pressure. Unfortunately, later owners and uninformed restorers thought the zerk fitting was for pumping in chassis grease - which they did, ruining the sector teeth after a short time because the chassis grease was squeezed out from between the teeth and the worm gear = no lube. Look at any used sector gear's teeth and you'll see wear gouges on their faces from lack of lubrication.
The zerk fitting in the sector housing, however, could be used for greasing the sector shaft, although the 600w (or Ford equivalent in "the Day") should have been able to work its way through the sector bushing grooves to coat the shaft. A little chassis grease pumped in here ONLY couldn't hurt, though. Just don't pump it into the gear box itself or you'll be joining the Hard Steering/Worn Sector Teeth Club in short order. Marshall |
