Old 07-11-2017, 04:58 PM   #1
CWells
Default Steering Column Fit problems 36 pickup
I mounted a 37 steering box and 40 frame bracket on my 1936 pickup. However, the angle of the steering tube going into the cab is such that it interferes with the fit of the toe board. It appears to me that the steering box needs to mounted about an inch higher so the toe board can fit normally. Anyone had this problem when installing a 37-40 box in a 35/35 pickup. CWells
CWells is offline   Reply With Quote
Old 07-11-2017, 06:19 PM   #2
johndee138
johndee138's Avatar
Default Re: Steering Column Fit problems 36 pickup
Had to notch my toeboard a smidgen in my 36 car. maybe 3/4" if I remember correctly.
Worth EVERY bit of trouble it caused getting the old bracket out etc.
johndee138 is offline   Reply With Quote
