Old 05-30-2017, 10:33 AM   #1
olut
olut's Avatar
Default Air Filter - or - not to filter the air ?
Short description:
35-A with original Zenith, air filter attached last fall, worked well, no significant loss of power, did not run rich or lean, ambient temperature below 80s.
The past two days we have high summer with temperatures in the 90ies, all fine when engine is cold, but as soon as the baby is getting warm, engine wants to die when accelerating, backfires and stops misbehaving only at low RPM, adjustments on the GAV dont resolve the problem.
So I removed the air filter and all is perfect.
Reason: that carb is not "air balanced" to be used with an airfilter (like those in my other babies 76-A and 165-D), cold intake air has less volume than hot intake air, if there is a certain flow rate limit at the filter and this is been exceeded due the high intake air temperature (close at the exhaust flange), then the carb should mix rich, but backfiring is always an effect of lean mixture......
...sounds not realy logic, where is the error in my point of view ?
...any thoughts ??
Best Greetings from hot Vienna
the best medicine to avoid mid life crisis.....
olut is offline   Reply With Quote
Old 05-30-2017, 11:16 AM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: Air Filter - or - not to filter the air ?
I think that's backwards. Cold air is MORE dense than hot air...
https://en.wikipedia.org/wiki/Density_of_air
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-30-2017, 11:27 AM   #3
160B
160B's Avatar
Short description:
What kind of air filter, paper, K&N?
Can you post a photo of the air cleaner you removed?
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 05-30-2017, 11:31 AM   #4
SeaSlugs
SeaSlugs's Avatar
yup - heard of an old trick of race cars they would dump dry ice in the air box to added oomph. Dont know how true that is or not...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-30-2017, 11:38 AM   #5
160B
160B's Avatar
Info from MODEL-A.org
http://www.model-a.org/filtering_air_into_carb.html
Carburetors, with their air input totally unfiltered, suck in all kinds of stuff that can do damage to your engine. Fine silica dust and powdered rock are the most common materials that are pulled in and cause engine wear.
The Air Maze, metal gauze unit (sold by most Model A Ford part distributors; shown on the left) prevents large particles from entering, but does nothing to filter out the small stuff that most commonly causes the damage.
The next logical step is to try paper element cartridges. However, you have to be careful not to restrict the air to fuel balance of the carburetor. The level of air resistances varies depending on the size, surface area, and the physical attributes of the filtering material.
An undersized filter restricts airflow into the carburetor and lowers the pressure at the choke. These consequences make the fuel-air ratio higher (too much gasoline for the airflow reduction) and also lower the velocity of fuel flow through the Venturi (reducing engine responsiveness to throttling). The result is carbon deposits in your engine from the rich mixture.
One needs to consider the air volume needs for a nominal 200 cubic inch engine at 2,800 RPM and the carburetors air intake area of 1.767 square inches. You also have to consider how much to oversize the filter element to allow for clogging up to say 30%. With some rough calculations, you'll find that you need a large filter.
I've read material from multiple sources, which say: "automotive engineers regularly size air filter surface areas at one-half an engines cubic inch capacity", which is 100 square inches for the nominal Model A engine.
I have found paper filters clog up quickly, restrict flow, and retain gasoline from drippy carburetors for a long time. So, I prefer K&N washable, oilable and reusable filters. Using published K&N formulas, I calculated the filter required for a typical Model A engine. If your engine has been modified to increase the cubic inches, you will want to adapt my following calculations.
First, I calculated the Effective Filtering Area for the physical attributes of K&N filter materials:
200 Cubic inches displacement times 2,800 RPM divided by 20,839, which is the factor for K&N Filter Attributes = 26.9 square inch Effective Filtering Area.
Then, I calculated the minimum length for a filter to fit in an Air Maze housing:
26.9 square inch Effective Filtering Area divided by (3 & 1/2 inch Air Maze diameter times 3.14 Pi) plus .75 inches to compensate for the rubber seals on each end of the element = 3.2 inches minimum filter length.
This is significantly longer than the very small air filters commonly seen on many Model A Fords.
K&N offers several filters that can be used with the Air Maze housing.
Part # E-3050 is 3.5 inches long.
Part # E-9257 is 5.5 inches long.
Part # E-2040 is 6.625 inches long.
To provide some margin for the filter getting dirty, before you get around to cleaning it, I would recommend the 5.5 inch long length. I know it is an over kill, but I am currently using the 6.625 inch long one to allow for driving on dusty gravel roads and to extend my time between filter cleaning / re-oiling cycles.
CAUTION: Regardless of any filter that you choose to use, you have to be watchful for a leaky carburetor that can load the filter up with gasoline and be vulnerable to ignition from the exhaust pipe and possibly cause a disastrous fire.
Important notes on the use of Air Maze housings:
When mounting an Air Maze housing onto a Zenith, Model A carburetor, it is important that a lock washer and nut be used to keep the screw from coming loose and allowing the Air Maze housing to fall to the ground. The screw and nut can be seen at the top of each photo.
To minimize air leaks at the point where an Air Maze connects to the Zenith, Model A carburetor, I use an o-ring (1-7/8" OD and 1-1/2" ID) on the carburetors air intake.
To use a long filter in the Air Maze, the large wing bolt needs to be replaced with a long 1/4 - 20 bolt or with a threaded rod, with nuts and lock washers.
Old 05-30-2017, 12:17 PM   #6
1955cj5
1955cj5's Avatar
Cold air has more density but less volume for a specifc weight...thats why a warm balloon will shrink when cooled...
The 15:1 ratio that makes our engines run is based on weight, not volume.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-30-2017, 01:27 PM   #7
Dick Steinkamp
I think we are agreeing? More weight (mass) in cold air than in the same volume of warm air. (Charles’s Law)
Old 05-30-2017, 02:32 PM   #8
olut
olut's Avatar
that was the air filter I removed today, had no other option, otherwise would have had to trailer back my Model A...
https://www.macsautoparts.com/ford_m...sh-filter.html
Old 05-30-2017, 02:48 PM   #9
olut
olut's Avatar
this is the setup in my RHD Fodor Town Sedan, the filter is in a much cooler area and does not make any trouble. I know, without an air filter you get a lot of stuff into the engine you don't want to know it there. So I ordered an air filter balance new carburetor from the US, but I need to be patient, it is on backorder....
Theoretically I can do the same air filter setup on my 35-A as well, although it is (now) a LHD, am I wrong ??
File Type: jpg 11947716_1633878596850174_2359031684604442060_o.jpg (87.0 KB, 143 views)
Old 05-30-2017, 02:52 PM   #10
olut
olut's Avatar
thank you for this very informative facts, isīnt the paper filter having even more resistance than the mash filter ?
I am actually dealing with the combination of far too hot intake air through an air filter and combined with a non-air filter balanced Zenith.......
...what if I relocate the air filter more to the front near the radiator to get cooler air ??
Old 05-30-2017, 02:53 PM   #11
Jason in TX
Jason in TX's Avatar
1932 Factory option. Very Rare. I just sold one here.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 05-30-2017, 03:22 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
That paper filter is much to small and restrictive. As noted in the posted by 160B from modela.com you need a minimum 5.5" K&N.
Old 05-30-2017, 04:47 PM   #13
160B
160B's Avatar
FWIW
I have the K&N E-3050 on both my Model A's and have close to 40,000 miles without any problems.
The info in the post from MODEL-A.org clearly states the minimum length should be 3.2 inches, and the E-3050 is 3.5 inches.
Also note the MODEL-A.org calculation is based on an engine RPM of 2800 RPM, I have a Mitchell overdrive and typically cruise around 2100 to 2200 RPM.
So as I see it the 3.5 inch filter is approximately 10% oversized and I run at 2200 rpm which is approximately 20% reduced cfm as your rpm goes down so the cfm through the carburetor. So the E-3050 is adequately sized unless you are cruising at 2800 RPM.
The post also notes "I know it is an over kill" for the 5.5 inch K&N.
Old 05-30-2017, 05:59 PM   #14
Nabco
Nabco's Avatar
I was using an Air Maze and the car ran like crap so I took it off and she started running great, ran it without a filter all last summer but was worried about what I was sucking up into the engine. This spring I put a High Boy on her and she is running great, I think it has to do with the filter being up in the cooler air.
1930 Deluxe Coupe
"Sister"
Nabco is offline   Reply With Quote
Old 05-31-2017, 11:35 AM   #15
Jim Brierley
I have never run a filter on any of my A's, and put a minimum of 2,000 miles a year on them. I also live on a dirt road. Been doing this since 1958. Engines show no signs of abnormal wear. If it ain't broke, don't fix it.
Old 05-31-2017, 11:45 AM   #16
SeaSlugs
SeaSlugs's Avatar
I wonder how much dust it actually sucks up. I live in farm country so planting/ harvest seasons theres ALOT of dust in the air (looks like a sand storm you see in arizona) or if your following a car on one of those dirt/rock roads it kicks up an amazing amount. Its gonna pass right thru the radiator but I wonder how much is actually reverse sucked into the engine since the intake is rear facing...
I mean if it sucked up cinders or small pebbles sure I can see the damage done but clay dust has been a thickener in many oils thru the years and cant see what damage it could do.
Old 05-31-2017, 11:46 AM   #17
George Miller
George Miller's Avatar
I.m with Jim. I also have been running Model A's since the 60ts. No air filter.
My 28 coupe 28,000 on the engine when I sold it last month. Used no oil, ran great, never had to add water.
George Miller is offline   Reply With Quote
Old 05-31-2017, 12:44 PM   #18
Peyton
Just wrap and secure a home air conditioner vent filter (Lowes) around the mesh on an air maze. I believe the size is 4" by 8". I use a wire catch to affix the filter to the mesh.
Does not seem to restrict my Tillotson and gets quite dirty within a relatively short time. That suggests that it is catching a lot of dirt.
Peyton is offline   Reply With Quote
Old 05-31-2017, 02:23 PM   #19
olut
olut's Avatar
...I just ordered a high boy, will see, how that is going to work...
thank you guys for all your input
Old 05-31-2017, 02:30 PM   #20
Nabco
Nabco's Avatar
Be sure to let us know.....
1930 Deluxe Coupe
"Sister"
