Old 05-22-2017, 07:55 AM   #1
Brian in Wheeling
Brian in Wheeling's Avatar
Default 29 tudor rain gutters
Opinions please. For a non-points car. Which two piece side rain drip rails are "best" i.e. easy( or easier) to install and look good the aluminum or the original steel?
Also, are there instructions for bending the rear two piece steel top moulding?
How does one do this to not screw it up?
Thanks,Brian W.
Brian in Wheeling is offline   Reply With Quote
Old 05-24-2017, 07:39 PM   #2
Brian in Wheeling
Default Re: 29 tudor rain gutters
O.K. So, no one has any experience or opinion on this? I'll bet a few of you have replaced the drip rails and other top mouldings doing a top or during a restoration.
Brian W.
Old 05-24-2017, 08:20 PM   #3
Big hammer
No experience with 29 and only experience with my 31, use an original if at all possible!
Bending the aluminum are a pain in the hands! Don't use flame for heating, drip.
Between my hands I worked it around a solid object, oxygen tank cap I think. Rubbing it back and forth while pulling towards me. Started at the backend worked to the front, started a nail and pulled into place. Caveman like but it worked for me. For the back I got lucky and reused what came off. Don't set the nails tight until your done, because there a real pain to remove if you have to, I think I worked several days pure side. Painted after installed, that was way to many years ago and probably forgot a lot of steps.
get a bigger hammer tap done
Old 05-25-2017, 02:21 AM   #4
juke joint johnny
juke joint johnny's Avatar
I bought a 29 Tudor 2 years ago that had one missing.
I bought an original one from Berts of Denver .much easier than messing around with the repro ones .I would call Steve and see if they had any He is on the Fordbarn .I think his name on here is Steve31
If I had to use the repros I would try the steel ones at least you could use some heat on them.
juke joint johnny is offline   Reply With Quote
