Old 05-11-2017, 06:24 PM   #1
buns014
Default radiator flushing
I'm looking for some advice on flushing the radiator on my 31 towne sedan. I have a huge mouse nest that I can see from the top made of seat stuffing. (i left the lower radiator hose off the motor about 30 years ago.)The nearest radiator shop is over an hour away.
Thanks in advance,
Jeff
Last edited by buns014; 05-11-2017 at 06:26 PM. Reason: forgot part of what i was stating.
buns014 is offline   Reply With Quote
Old 05-11-2017, 07:32 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: radiator flushing
Take it out turn it over and back flush with hose. Once it's back in, if you have a overheating problem, you can use evaporust thermocure, which I'm hearing good reviews on . Check the archives, as it was just recently discussed.
Old 05-11-2017, 08:32 PM   #3
noboD
Drive to the radiator shop!!
noboD is offline   Reply With Quote
Old 05-11-2017, 09:05 PM   #4
iverson
iverson's Avatar
I think a piece of thin wire with a hook bent into it and a lot of time will fish out the stuffing
iverson is offline   Reply With Quote
Old 05-11-2017, 09:29 PM   #5
Big hammer
I think fishing is the wrong terminology:-)
Mechanical removal, then some compressed air, then lots of water, I wouldn't spend a lot of time or money before replacing! Mice urine is corrosive.
Old 05-11-2017, 09:32 PM   #6
Quigley1930
Quigley1930's Avatar
See below.
Quigley1930 is offline   Reply With Quote
Old 05-11-2017, 10:38 PM   #7
SeaSlugs
SeaSlugs's Avatar
old sump pump or pool pump back flushing it with a solution of simple green for 20+ minutes will clean it.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-12-2017, 04:57 AM   #8
RonC
RonC's Avatar
Fill with water and draino off the car for about 20 min. Backflush and repeat if necessary. The mouse crap will be welded inside. Wear eye and skin protection. The lye cleans very well. 20 mins max between flushes. You could follow up with evaporust or rust911. Make a backflush tool that uses air and water. Gently apply air bursts.
RonC is offline   Reply With Quote
Old 05-12-2017, 10:03 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
You need lots of flow and some pressure, so I used a sump pump to back flush my 28 a few years ago. As Big hammer said, there is very little that is more corrosive than mouse piss. It also can be deadly if you breath mouse droppings dust, so use care.
Old 05-12-2017, 10:14 AM   #10
SeaSlugs
SeaSlugs's Avatar
thats what i did using a pool pump - mostly old grease and bug parts (darn asian beetles for some reason) were clogging my radiator. Block wasnt too bad - just some fine silt and rust particles but i cleaned with a special made air wand and lots of poking when i was rebuilding it to get the water passage sparkling clean.
Old 05-16-2017, 07:14 PM   #11
buns014
that's pretty slick. I"m going to try that for sure.
Old 05-16-2017, 07:17 PM   #12
Tom Wesenberg
Notice the gentle curve on the 90* elbow I used. This will give much better flow than the sharp elbow.
Old 05-16-2017, 10:42 PM   #13
denniskliesen
denniskliesen's Avatar
Yeah and I like that fan shroud you have there Tom. Does anybody here ever see those for sale at the meets? Sorry, didn't mean to hijack the thread.
denniskliesen is offline   Reply With Quote
Old 05-17-2017, 06:32 AM   #14
Tom Wesenberg
Once in a while they show up on ebay, but they are rather expensive.
Old 05-17-2017, 06:59 AM   #15
BoysToys1928A
BoysToys1928A's Avatar
Tom I have a quick question about the Sump pump, I notice that the one attached to the engine looks to be hooked up through where the water pump is, not the top of the engine where water would flow out and into the radiator. Am I wrong in what it looks like or is this the correct way to attach this rig? I am getting ready to do all this flushing and love the idea ! Just want to hook it up right. Also did you run your engine with the sump pump hooked up ?
Larry
"All you have to be is smarter than what you are working with" Larry Stout Quote thats me... Few old men finish well.
BoysToys1928A is offline   Reply With Quote
Old 05-17-2017, 07:06 AM   #16
Tom Wesenberg
The sump is pumping into the side inlet, and the return flow is out the top front, where the pump is mounted.
Be sure you use a grounded outlet for the power. The sump pump is metal, and you're playing in water, so you don't want any shocks.
I recently installed an outdoor outlet for 110 and 220, and I use the ground fault for added safety.
In the 70's a friend of my cousin was killed while taking a bath and the radio fell into the tub.
Old 07-28-2017, 03:28 PM   #17
CB919ER
CB919ER's Avatar
My radiator is still full, but I'd say 20 year old coolant, I guess I should flush it out and replace? it still looks nice and green
CB919ER is offline   Reply With Quote
Old 07-28-2017, 03:43 PM   #18
JDupuis
JDupuis's Avatar
CB919ER..flush that 20 yr old coolant out. Old coolant become acidic with time.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 07-28-2017, 05:37 PM   #19
Synchro909
Synchro909's Avatar
The OP said that he left the bottom hose off. Wouldn't that mean the mouse nest is in the bottom tank and in that case, wouldn't BACK flushing be the wrong way to go? You'd be trying to push the nest through the core. On the other hand, he said he can see the nest from the top. In THAT case, back flushing would be the way to go
My suggestion - pull as much of the nest out through and flush from the appropriate direction. You might use a dental mirror or fibre optic inspection camera to check progress as you pull out the crud. I doubt any of the chemicals mentioned above will have any affect on seat stuffing. The mouse crap might be though.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-28-2017, 09:31 PM   #20
Drive Shaft Dave
Yes , that dried up mouse crap carries the Hantavirus, very deadly use a good mask.
Drive Shaft Dave is offline   Reply With Quote
