Old 04-28-2017, 07:26 PM   #1
vstol
Default John Deere corn head grease
I read about JD corn head grease for trains and rear end when I went to the dealer I found the grease in tubes. So how do you put the grease in the trains and rear end or do I have this totally screwed up.
vstol is offline   Reply With Quote
Old 04-28-2017, 07:50 PM   #2
harleytoprock
Default Re: John Deere corn head grease
The corn head grease should be used in the universal joint housing for the u-joint. Not in the rear end, use 600wt. What do trains have to do with Model A's?
harleytoprock is offline   Reply With Quote
Old 04-28-2017, 07:56 PM   #3
Glenn C.
Glenn C.'s Avatar
600 wt oil for transmission and rear end. Corn head grease for universal joint
Glenn C. is offline   Reply With Quote
Old 04-28-2017, 07:58 PM   #4
vstol
Transmission not trains, trans got changed to trains, will have to reread the text closer next time
Old 04-28-2017, 08:35 PM   #5
redmodelt
redmodelt's Avatar
Cornhead for the steering box. Warm it up before trying to put in.
Old 04-29-2017, 08:24 AM   #6
JBill
Grease (of any kind) in the steering box? This doesn't sound right. I use the same lube as in the transmission and differential. And no, the steering box doesn't leak.
JBill is offline   Reply With Quote
Old 04-29-2017, 08:25 AM   #7
JBill
PS: I do use JD cornhead grease for the U-joint.
Old 04-29-2017, 08:56 AM   #8
old31
Use JD for both the steering box and the universal.
old31 is offline   Reply With Quote
Old 04-29-2017, 11:27 AM   #9
HoarseWhisperer
HoarseWhisperer's Avatar
The warning to "never put grease in the steering gear" per Ford Service Bulletins and other sources is well published.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 04-29-2017, 11:47 AM   #10
wrndln
John Deere Corn Head grease is made differently than regular grease, like axle grease. It clings to the gears instead of running off when the gears stop moving. It is a different type of grease that will work in a steering box. I am pretty sure it will work fine in a steering box.
Rusty Nelson
Old 04-29-2017, 12:30 PM   #11
Joe K
Joe K's Avatar
Rusty Nelson
Has been recommended for a while - it's "sticky" more like the original STP is sticky.
But STP is NOT a lubricant.
Sorry. 1930 was a good year - but some things have improved since then.
Certain greases being one of them.
I have greased corn heads using JD corn-head grease and think one is challenged to correctly call it a grease. I don't think it an emulsion at all (like traditional grease.)
Joe K
Shudda kept the horse.
Old 04-29-2017, 12:30 PM   #12
160B
160B's Avatar
Rusty Nelson
I have JD Corn Head grease in my 1931 68B steering box for two years, it works great. I did try heating it in boiling water to allow easier adding to the steering box. I found that the viscosity did not change much, almost no change. I finally spooned the corn head grease into a restaurant type plastic catchup dispenser and squeezed the dispenser to get it in the steering box. Then I tamped it down with a round dowel, so I could add more. I then checked the grease level frequently until the level remained the same.
http://www.cenex.com/~/media/cenex/f...pds-h9-02.ashx
"Corn Head Grease is a carefully formulated lithium 12-hydroxystearate grease with oxidation, rust and corrosion inhibitors, extreme pressure (EP) additives for antiwear and heavy shock loading, and a special polymer to control oil separation during storage. The base oil used is a high viscosity index lubricant which provides excellent stability under various temperature conditions."
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-29-2017, 07:03 PM   #13
duke36
I have dedicated grease gun from Harbor Freight loaded with the corn hd tube. Also, a removable pipe plug in the bottom of the steering gear. Pump until it runs out and then check grease fitting at top of casting. Turn steering wheel back and forth to work in grease.The top "zerk" is installed in a brass "adaptor" that fits the stock thread and can be removed by hand to check level. The steering gear takes quite a bit from the tube.
Old 04-29-2017, 08:35 PM   #14
JBill
No thanks, but you go ahead. I'm sure it will be just fine.
Old 04-30-2017, 09:44 AM   #15
old31
I understand why many of you have changed to JD grease. The stuff works, and works well.
I pump it into the zerk opening until it comes out.
