Old 04-09-2017, 02:13 PM   #1
OLD AS I
OLD AS I's Avatar
Default how to soften cork
Am about to connect transmission to drive shaft, ('46 59 engine) the cork seal that goes in the 2 piece cap for the universal joint, its perhaps 3/8" x 1/4", am afraid to bend it, what can be used to soften the cork material, light oil, heated water, steam, heated oil ????
OLD AS I is offline   Reply With Quote
Old 04-09-2017, 02:43 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: how to soften cork
Warm water. Someone makes a rubber seal that works pretty well too.
Old 04-09-2017, 06:08 PM   #3
trevo
I recently replaced the cork halves massaged a little heavy oil into them all up and running now no issues
trevo is offline   Reply With Quote
Old 04-09-2017, 09:38 PM   #4
Old Henry
Old Henry's Avatar
New one is in this tranny gasket set from C&G for $7.95: https://cgfordparts.com/ufolder/cgca...&sp=Search+%23
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 04-10-2017, 05:50 AM   #5
OLD AS I
OLD AS I's Avatar
Old Henry
Yes, thanks, have sets from Drake and feel they are fairly new, just would like to take that extra step. Also am in Canada and getting items from the US doubles in cost when taking in to consideration shipping, duties, currency exchange, brokerage fees and the time for shipment.
Old 04-10-2017, 08:13 AM   #6
19Fordy
19Fordy's Avatar
I know that there are folks who swear by the traditional cork seal and there are those who swear at it. Since my rear end is out I checked the cork seal which had been in place for about 48 years and found it to be whole and in place but, very brittle and no longer "swelled up" for maximum sealing. Wish there was a way to reduce Canadian costs. There's a blue O-ring style neoprene seal on Ebay that has good reviews.
Old 04-10-2017, 05:55 PM   #7
Gary Tosel
Gary Tosel's Avatar
When I installed the cork seals, I soaked them in engine oil.
Another item to observe is that back many years ago, the cork seal was shaped with two sides longer than the other, not square. This shape allows the cork to form better between the clam shell and the ball shaped part of the drive shaft. I have them in my car over 20 years and no leaks. Just my 2 cents worth.
Gary Tosel is offline   Reply With Quote
Old 04-11-2017, 08:59 AM   #8
J Witt
J Witt's Avatar
I use vaseline on the cork joints on my horn (oboe) and it keeps them in good, pliable condition. It doesn't last too long, though. I'd think that the lubricant that's being sealed in would keep the cork pliable after installation.
If there is a modern rubber seal material that fits, that would be a better bet. I expect the amount of sitting some of these cars do would tend to let the cork dry out.
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
